toyota l.s.d help
Posted: Mon Mar 16, 2009 4:08 pm
by J_Dub
diff code on my yn60 is G254
G=8.0"
25=4.5 ratio
4=4 pinion open
so originally it had this, but then reading some info, it was stated that sometimes Toyota got the codes wrong and to check the fins on the diff housing..
3 fins = 2 pinion
4 fins = 4 pinion
mines got 3 fins which is 2 pinion, different to what vin plate says...
Its got an l.s.d in the rear, both wheels spin same way when i jack it up, so how the hell am i to know exactly what diff ive got when its now got a l.s.d, factory came out with 4 pinion open (apparantly) but its got a 2 pinion diff housing....
Re: toyota l.s.d help
Posted: Mon Mar 16, 2009 4:22 pm
by coxsy
jack the rear up mark drive shaft rotate the wheels once count drive shaft revolutions
Posted: Mon Mar 16, 2009 6:00 pm
by gimmemud
take it out and have a look. mine had 4.3 stamped on it
Posted: Mon Mar 16, 2009 6:12 pm
by Jafa
J_Dub wrote:diff code on my yn60 is G254
G=8.0"
25=4.5 ratio
4=4 pinion open
3 fins = 2 pinion
4 fins = 4 pinion
Its got an l.s.d in the rear, both wheels spin same way when i jack it up, so how the hell am i to know exactly what diff ive got when its now got a l.s.d, factory came out with 4 pinion open (apparently) but its got a 2 pinion diff housing....
Not necessarily, you can get a 4 pinion in a 3 fin case.
the 3 fin case is generally known, esp in the US as a 4cyl carrier, and the 4 fin jobbie as the V6 carrier.
Best way is to spin the road wheel one turn, and count how many times the driveshaft spins, or pull the head and count the teeh on both ring and pinion, divide ring gear # by pinion # will give you teh ratio.
Posted: Mon Mar 16, 2009 6:23 pm
by J_Dub
sweet, will do the rotate wheel thing, gona pull out front end anyways, and strip axle/diff, since im unemployed may aswell do a bita serviceing, will do seals etc, diff drain bolt is rounded so good chance to get that out and replace, paint all the bits and hopefully fit a front l.s.d or locker if money allows
Posted: Wed Mar 18, 2009 7:49 am
by Slideways
I found this site with reference to the G and K codes etc, might be useful.
http://www.cruiserfaq.com/09-01.php
Posted: Wed Mar 18, 2009 8:41 am
by J_Dub
saweeet, that sites telling me, i got factory 4.5 l.s.d
where as another site told me i got 4.5 open
its deffinately l.s.d, and all references tell me i got 4.5, and they do say the code might not always be correct, so pretty damn sure its 4.5, will jack it up today or tomorrow and check d/s rotations
plan is to, fit l.s.d (tight 1) to the front, then way way way down the track get air locker for the rear
