Bleeding air from power steering system.
tgaguy1
Post by tgaguy1 »
I need to know how to bleed air from the power steering system in A 94 l200.
The system has had a hose replaced and now is very noisey and stiff in operation.
I recall a thread on here some time ago on this topic, but I am unable to locate this using the search.
Can someone either give me a link to this old thread or cover the proceedure again for me.
Thanks
Jase.
mudzilla
Re: Bleeding air from power steering system.
Post by mudzilla »
Top up the fluid, then with the engine running turn the steering from lock to lock a few times, keep an eye on the fluid level.
tgaguy1
Post by tgaguy1 »
mudzilla wrote:Top up the fluid, then with the engine running turn the steering from lock to lock a few times, keep an eye on the fluid level.
I have tryed that. In the past air has cleared itself. This time I seem to have a stubborn air lock.
H2OLOVA
Post by H2OLOVA »
loosen one of the hoses until you get fluid coming out then do the lock to lock thing. You'll have to keep a close eye on the fluid level.
Jafa
Post by Jafa »
This is for a Howe system, but works for others
http://www.howeperformance.com/pdfs/bleed-instr.pdf
021 273 9942
jafa@inspire.net.nz
flyingbrick
Post by flyingbrick »
I vote take it for a drive 8)
I've never had one bleed itself out in the garage properly.. for some reason a 30 second blast up the street ALWAYS seems to do it.
No idea why.. have always done what was explained up there by the other posters.
-NAthan
nzhunter
Post by nzhunter »
try jacking up the front axle and going lock to lock it always seems to bleed up easier
tgaguy1
Post by tgaguy1 »
Thanks for your replies. I will try jacking the front up and if that fails will try cracking the hose fittings.
Return to “Tool Shed”
