My ignition key is the older type where the lights & ignition are one unit vs separated as found on late 2a & 3 Series.
Simplified, the ignition key has one 'hot' input wire and two output wires which feed various parts of the Land Rover's electrical system. I've no idea how much load those wires carry. I'm planning to use a 30amp relay as the middle man instead of the ignition key.
Is a 30 amp relay big enough to carry the electrical load which used to run through the ignition key circuit ?
Thanks.
