How do you all get your safari into 4wd. Mines an Auto and with the motor running and the trans in neutral i have a 50-50% success rate. It'll go into 4H fine but then will stop when going into 4L (asif the gears are not meshing) and then any attempt to move the lever forwards or backwards after this will result in gears grinding.
Sometimes its fine.. sometimes its not. Its asif my neutral is kinda not being neutral enough.
Any ideas? sometimes its no issue- sometimes i have to turn the engine off- slot it into 4wd and then restart
