Toyota MR2 Caliper Coversion kit
From lockers to air deflaters, if it has to do with wheels tires or axles, you can find it in here.
Moderator: Vendors
Jafa
Post by Jafa »
Awaiting brackets from laser cutting, should be available for shipping on 16th April
Use this bracket kit to convert your Hilux or Cruiser to four wheel discs using Toyota MR2 non turbo rear calipers. Mounting bracket is cadmium plated for corrosion resistance, and the spacers are stainless. Kit includes 2 brackets and 4 spacers.
$125 inc gst
021 273 9942
jafa@inspire.net.nz
Re: Toyota MR2 Caliper Coversion kit
PM Sent... :wink:
haydgq
Post by haydgq »
Jafa wrote:Awaiting brackets from laser cutting, should be available for shipping on 16th April
$125 inc gst
Good to hear Jaffa, And from what i have heard from a MR2 Guru (Vvega,s mate in Palmy called Tex) is that its all the calipers from that series of Mr2 that fit and just the later model ones that have a different offset or something.!!
vvega
Post by vvega »
later model ones have a way thicker disc and a much larger diameter ... there also the proverbial rocking horse shit
Kiwi4x4
The ones you need have 16v on them, these are the ones to get apparantly, with the handbrake connection what is needed to connect up the cable to them??, the ones I have here have a lever by the looks of it.
lilpigzuk
Tiger Balm
Post by lilpigzuk »
Jerry wrote:The ones you need have 16v on them, these are the ones to get apparantly, with the handbrake connection what is needed to connect up the cable to them??, the ones I have here have a lever by the looks of it.
Thats what Ive been trying to work out, but no one seems to know. Rotazuk got some off a AW11 Mr2 which is the early shape (square with the 4AGE or 4AGZE). These are our of the N/A ones
I also have these ones of the later model MR2 which I stripped (SW20, rounder shape, with 3SGE or 3SGTE - think thats right). It was the turbo version and the callipers look identical to the ones people have used, so Im getting a little confused now......
looking at them they are very similar but the early MR2 is narrower - solid disc, where the later ones were vented, hence wider calliper.
vvega
Post by vvega »
yeah sw20 .. turbo and non turbo are the same till the gen3 1994 then they get bigger
aw11 ones are good if you wanna runt he ln65 non vented discs ...to keep the mud out
Kiwi4x4
hosehustler
Post by hosehustler »
That 2nd pic is the one to use, I was told they were from the NON turbo, but if they're from a turbo who cares they're the ones that i've used on the vented prado rotors....
I purchased mine off the shelf, and so were Pete's neither donor MR2 was sited we were relying in the info from the wrecker
I hate signatures
hosehustler
hosehustler wrote:That 2nd pic is the one to use, I was told they were from the NON turbo, but if they're from a turbo who cares they're the ones that i've used on the vented prado rotors....
I purchased mine off the shelf, and so were Pete's neither donor MR2 was sighted we were relying in the info from the wrecker
I hate signatures
haydgq
Post by haydgq »
Yea same with my ones with 16 stamped into them but diff colour, All the ones ive seen have been Red.(Not that the colour matters eh)
mickey
Post by mickey »
will these fit cruiser full floating diffs?
Jafa
Post by Jafa »
mickey wrote:will these fit cruiser full floating diffs?
Pretty sure they will, check this thread
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=18&t=9827&st=0&sk=t&sd=a&start=570
021 273 9942
jafa@inspire.net.nz
haynzy
Post by haynzy »
no a hundy sure but i think the cruiser axles have a different pcd as I was hoping to get a copy of the ones petefj40 had done of 4wdaccessories but was told they would not fit my lux.
Jafa
Post by Jafa »
Ahh I see, well there ya go. Mickey, measure the pcd of the bolts that hold it on
021 273 9942
jafa@inspire.net.nz
Jafa wrote:Ahh I see, well there ya go. Mickey, measure the pcd of the bolts that hold it on
This is the bolt spacings on my full floating cruiser diff, is that what your brackets are setup for jafa?
haynzy
Post by haynzy »
nope they wont fit that but im sure he could make them work :wink:
haynzy wrote:nope they wont fit that but im sure he could make them work :wink:
That clears up some cruiser confusion, cheers Haynzy :mrgreen:
rangimotors
Post by rangimotors »
just to confirm, there is no difference between the brakes from a turbo sw20 and a non turbo sw20 so back brakes from either will be fine.
vvega
Post by vvega »
no differance in the rears :D
Kiwi4x4
Jafa
Post by Jafa »
Well thats munted aint it? fawkn cruisers! :lol: :lol:
I could get more done that would fit ff cruisers, but how many people are interested in a set?
021 273 9942
jafa@inspire.net.nz
us, 40 foater one please :D
andrew007
Post by andrew007 »
count me in for set thanks jaffa ;hilux db cab with custom panel mods :lol:
mickey
Post by mickey »
count me in.
Had a look under the back of the POS today with regard to these new brackets, from what i can see mounting plates should bolt up....
These are the MR2 Calipers I have sitting here
My existing handbrake cable(s) move in from the caliper to the centre of the diff, the MR2 handbrake mechanism appear to activate to the rear of the vehicle. Any suggestions on how to connect this?, swopping them leaves them in the same position
lilpigzuk
Tiger Balm
Post by lilpigzuk »
hows progress Jafa?
Jafa
Post by Jafa »
hows progress Jafa?
Still at lectrolaters, I'll nag them tomorrow, or later today :lol: :lol:
021 273 9942
jafa@inspire.net.nz
1rugger
Post by 1rugger »
I'll take a pair as well :mrgreen: assuming they will fit 95 kzn130 hilux rear diff.
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
Jafa
Post by Jafa »
Ok, the Hilux/Surf kit is on the shelf, ready to go, so purchase them though the website here
http://www.snr4x4.co.nz/caliper-bracket-conversio-p-238.html
Full Float Cruiser kit is still in the works.
021 273 9942
jafa@inspire.net.nz
bigstu
Post by bigstu »
maybe able to fit ae82 92 and 101 rear calipers the mr2s look very simular if not the same as the ones on my levin gtz i had prob a dime a dozen to compared to buying them as mr2 items
1rugger
Post by 1rugger »
got the brakes,brackets and disk's all bolted up today :mrgreen: but the handbrake lever hit the leaf pack. was wondering if anyone has hit this problem before and what solution they came up with :?:
Return to “Axles Tyres and Wheels”
