I need a starter, I hears SD1 starters are different to Range Rover ones? Anyone confirm?
Ideally an old V8 that is buggered but still has all the ancilleries such as alternator and PS pump.
Cheers, Glen
Wanted - Rover V8 parts
Re: Wanted - Rover V8 parts
NJV6 wrote:I hears SD1 starters are different to Range Rover ones? Anyone confirm?
Yep they are different. The difference is the sd1 solenoids hang down off the bottom and the RR ones are oriented to the side
I do have a stuffed motor here but I think shipping will be a major downfall
Do RR ones still bolt up to a SD1 motor? I imagine they would...
NJV6 wrote:Do RR ones still bolt up to a SD1 motor? I imagine they would...
yes they do
