Ah i now understand, how annoying. Im not so familar with suzuki's so might not be that helpful, if no one knows where the wire goes i would just be pulling a few pannels off and you could thread something down the hole like a peice of that blue band used for strapping boxes (breaking into cars) and find where it comes out, then you should find the same colour coded wire and hopefully you can chuck a new bit back through by extending it, attaching it to the band and pulling it through.
Did that make any sense, someone else may know exactly where it goes and have a better method of doing it..
I was hoping to not pull all the panels out. But it's looking that way. I figured it not coming down through the seatbelt pillar.So it must be coming thru the door sill near the hinge. Hmm I was thinking the No.8 wire to thread it.
Splicing the wires is not an issue. Just finding the bugger!
The other guy is right you need to get access, the same thing was done to ours, the reason they are cut is when the door is open and the key is in the ignition the bloody thing beeps at you.
