As above, wanted to suit 1996 4wd hilux.
WTB: TJM T15
Re: WTB: TJM T15
Even consider just your standard AliArc bull bar
Re: WTB: TJM T15
is it worth seeing what an ARB one would cost? Badnuz can get you a good price seeing as he works for ARB, also thats an aluminium bar too isn't it?, a steel one would be stronger......
Re: WTB: TJM T15
T15 are available in alloy or steel. The difference is, if wanting winch compatible, a lot of TJM bars (all?) have a seperate winch plate to the bar, which some say offers a more secure/stronger mount for the winch, but is purchased seperately to the bar, so can be more expensive.
If I had a hilux I'd get a custom bar made, as the ARB etc can be damn expensive, only reason I run an alloy TJM is because of the stupid airbags on the Safari so needed something SRS compatible
Re: WTB: TJM T15
Jerry wrote:is it worth seeing what an ARB one would cost? Badnuz can get you a good price seeing as he works for ARB, also thats an aluminium bar too isn't it?, a steel one would be stronger......
Cheers mate, I've dropped him a PM.
Do you know off the top of your head what I might be looking at ($$$)??
Re: WTB: TJM T15
Prices can vary between dealers, I had quotes from $1800incl gst to $2100+ gst for the same bar
Re: WTB: TJM T15
Thank you DaveM. One more question, do you know if a bullbar (aliarc) off a 97 2wd hilux will fit a 4wd 96 hilux? I've had a look at photos on the net and they seem to match up.
