i got booted out on a warrent because my rims stick out to far past the gaurds
nissan safari offset
Safari Swb
does anyone know what the standard wheel offset is for nissan safaris??? im not running flares and i dont want rims that stick out past the gaurds, just nice and flush.
89 safari swb-4.2 auto..for sale
96 safari swb-2.8t manual..stock
Re: nissan safari offset
dont they come out with factory 7" rims or something?
Zero
Safari Swb
so -10 would stick out past the gaurd a bit wouldnt they??
http://www.trademe.co.nz/Browse/Listing ... =212449732
looking at those wheels
My 31's on factory rims stick out past the guards (just not the tread on the ground so legal) so I'd say so. Haven't ever put any other offset on though so not talking from experience.
Why don't you throw some rubber flares on? I did for my 15x8's no bothers. Took about 15min max an arch including taking the wheel on and off. A lot easier than buying and selling rims.
Yep 7" is standard for them. I run my silverstones on 7" rims and they are under the guards.
Al
Al
A 7" wheel with 0 offset was one factory spec. If you go to 8" wheel then to have the outside of the tyre in the same place approx you will need +12. Most Nissan spec 8" wheels you get are -11 as puts the inisde of the tyre in about the same place.
Safari Swb
i take it a -11 offset for example will stick out the gaurd further than a + 11.???
im just buying a set of rims for my road tyres as i dont want to use my muddies on the road
