R 151 TRANSPLANT ISSUES
Posted: Sun Apr 19, 2009 11:52 am
HAVE A 91 HILUX D CAB RUNNING A 3L AND IT'S G52 GEARBOX SPAT SO I BOUGHT A LINESIDE AUTOMOTIVE R 151, 3L BELLHOUSING AND ALSO A TRANSFER BOX THAT WAS INTENDED TO FIT IT
THAT WAS EARLY DECEMBER LAST YEAR AND AFTER DRAGGING THE CHAIN FOR AGES I MADE A START ONLY YESTERDAY
SO FAR:
-I CAN'T GET THE T CASE ONTO THE MAIN BOX OUTPUT SHAFT- I THINK THE JOINING TUBE'S TOO SMALL (SEE BELOW)
-DUNNO YET WHETHER THE INPUT SHAFT SPLINES (HAVEN'T COUNTED EM YET) ON THE G52 AND R151 MATCH UP, BUT EVERYTHING ELSE MEASURES OUT TO BE THE SAME
-HOPING THE X MEMBER FROM THE G52 WORKS ON THE R151 SETUP :-/
-NO IDEA WOT THE R 151 RATIOS ARE WOTEVER THEY ARE WILL HAV 2 DO I SPOSE
-THE ONLY IDENTIFYING WRITING ON THE BOXES WAS:
MAIN BOX - 1035 GM STAMPED ON FRONT CASE
- 1035 STAMPED ON REAR CASE WITH THE STICKS IN IT
- GLN 130 WRITTEN IN PAINT PEN
T CASE - W 628 / 130 ON A HANDWRITTEN LABEL
- 13 IN BLUE PAINT PEN WRITTEN ON THE T CASE
BELL HOUSING - LN 130 HANDWRITTEN
- W990 HANDWRITTEN
ACTION SO FAR:
TUBE PROBLEM.......IT LOOKS LIKE THE INTERNALLY SPLINED TUBE STUCK TO THE T CASE IS 4 MM OR SO TOO SMALL FOR THE MAIN BOX REAR OUTPUT SPLINE. T CASE LOOKS GOOD FOR BOLT UP OTHERWISE EXCEPT THE APARRENT ISSUE WITH THE TUBE. I MAY OF COURSE BE JUST NO GOOD AT PUTTING MY THING IN THE HOLE BUT I'M FAIRLY SURE I DID MY BEST!
BECOS I COULDN'T GET THE VERNIERS AT THE OUTPUT SHAFT, I RESORTED TO CUTTING A SMALL SQUARE OF PAPER AND PUTTING IT "DOWN THE HOLE" ONTO THE OUTPUT SHAFT AND RUBBING IT INTO A SORT OF OILY FINGERED TRACING - AFTER 3 GOES AT THAT I GOT 1 I COULD FINALLY CALL CLOSE ENUF FOR A SPLINE COUNT AND ROUGH MEASUREMENT WITH VERNIERS HENCE THE ESTIMATED 4MM OR SO SIZE DIFFERENCE.
MAIN BOX OUTPUT PAPER TRACE RESULT WAS - 23 SPLINES (SUBJECT TO 100% SURE COUNT)
- 32 MM OUTSIDE DIAMETER BEST ESTIMATE FROM BIT OF PAPER
T CASE TUBE - 28.2MM MAX. INSIDE DIAMETER (SPLINE TROUGHS)
- TUBE O.D. 37.58MM
- MAIN BOX TO T CASE SEAL POSITION THAT THE TUBE SITS AGAINST - 40.5MM
I KNOW THAT ALOT OF THESE R 151'S HAD THE CHAIN DRIVEN T CASE AND WITH THIS ONE I'M TRYING TO PUT A GEAR IDLER T CASE UP IT, SO THAT COULD BE THE REASON FOR THE 4MM DIFFERENCE...
HAS ANY1 ELSE STRUCK OR HEARD OF THIS TOO I THINK THE "PROPER" WAY 2 DO IT MIGHT BE TO CHANGE EITHER THE MAIN BOX OUTPUT OR TRANS BOX INPUT SO IT'S A CORRECT MATCH BUT THERES A BIT IN THAT AND THERE MAY BE A SIMPLER WAY
ANY IDEAS? THE TUBE PROB IS THE BIGGEST STOP SO FAR
SO FAR:
- W990 HANDWRITTEN
ACTION SO FAR:
- TUBE O.D. 37.58MM
