Reg on hold - NEEDS CERT. (use to be 2l) Considering selling - what do you think it's worth?
LN65 - beam axle front/rear
Things that need done-
L/H caliper overhaul (seals)
Needs front bumper, indicator/park lenses.
Clutch release bearing noisey.
Bent steering arm/damper - needs fixing
needs an airbox/snorkel
few bits n pieces minor jobs
selt belts etc need putting back in (all there)
fan currently mounted through radiator, haven't got around to relocating it.
good things,
6MGE, running 5m electronics - Also have midbowl sump with modified oil pump (not fitted) - ideal for angles. goes hard.
Low profile gearbox x-member
2.5" exhaust system, sounds fukn good.
Modified surf fuel tank (in-tank fuel pump)
Near NEW 33" Kumho KL71 on near NEW whitespoke 8" rims (less than 1mm wear) - retail around $2000?
Front LSD
4.88 diffs
Rear LOCKRIGHT
Very little rust, a tiny bit in rear floor pan
50mm bodylift
Good rear bar
New maxitrac big bore shocks and springs, nolathane bushes - 2" lift
Recent front axle seal overhaul
also have spare 5m block with number 2 big end bearing nipping up, and a 5m head with brackets for high mount alternator etc. Cert shouldn't be hard for this truck, it uses standard engine mounts etc. probaly just needs a driveshaft loop and things mentioned above.
Quite a capable truck, could do with more flex. anyone interested?
motor/box setup - $1500
springs/shocks/bushes - $1500
Tyres and rims - $2000?
Lockright - $600
1988 HILUX D/CAB - 6mge
Selling or wanted vehicles.
1 post
• Page 1 of 1
Jump to
- Site Information and Help
- ↳ ORE Forum Guidelines
- ↳ Having problems?
- ↳ Feedback
- ↳ Announcements
- 4wding in New Zealand
- ↳ New Members and Beginners
- ↳ Events
- ↳ Video Clips
- ↳ Stolen / Lost and Found
- In the garage
- ↳ Tech Section/Library
- ↳ 4wd Safety
- ↳ Tool Shed
- ↳ Drivetrain / Suspension
- ↳ Projects / Mod's
- ↳ Daihatsu
- ↳ Isuzu
- ↳ Jeep
- ↳ Lada
- ↳ Mitsubishi
- ↳ Nissan
- ↳ Range Rover / Land Rover
- ↳ Suzuki
- ↳ Toyota
- ↳ Tyres
- ↳ 4WD's Forsale / Wanted
- ↳ 4WD Parts
- ↳ ORE Courier Service
- On the track
- ↳ Trip Leaders
- ↳ Planning a trip?
- Vendors Showcase
- ↳ Axles Tyres and Wheels
- ↳ Body/Armor
- ↳ Suspension
- ↳ Electronics
- Event Organisation
- Offroad Racing
- ↳ General
- Other Forums
- ↳ The Bike Bar
- ↳ Fish'n
- ↳ Hunting
- Hall of Fame
- ↳ Hall of Fame - Builds
- ↳ Hall of Fame -Other
- ↳ Hall of Fame - Muppets
- Offtopic
- ↳ Where in the world is ORE
- ↳ Videos - Non 4wd Related
