surf starter motor probs??
Macca
Post by Macca »
I searched and couldnt find any relavent info re 2lte surf starters. Has anyone on here ever had problems with the ring gear losing teeth? or would it more than likely be the starter solenoid electrics?
symptoms are when i try to turn the key it just whirrs like the starter is spinning but not engaging :x . rock it a little in gear and it kicks into life. Has done this a couple of times. any help would be greatly appreciated.
simono
Post by simono »
Whirs but no engaging ???
Sounds very much like the plunger is sticking where it engages the bendix wheel.
I know the contact are usually a problem and have had mine out a few times for this but have never struck your problem.
If you are looking for a zero cost possible solution, I would pull the starter out, yeah we all know how much fun that is.
Pull the solenoid cover off.
Remove the plunger and spring and give the whole thing a bloody good clean, diesel and an airgun is good enough.
Hose it out with a little CRC or whatever and put it all back in.
See how ya go there.
That would certainly be my first approach.
Oh....consider replaceing the contacts while you are in there, they are about $7-$9 from Toyota.
1990 LN130 Surf 2.4LT
The “Grey Ghost”
My Photos
Macca
Post by Macca »
Yeah thanks for that. I had decided to do that when i next get a chance.Just a pain that today was my lastday of holiday and am back to work at 530 tomorow. Murphys law aye :roll: , lol
