terrano gearbox question
For all Nissan related topics
Ryan
Post by Ryan »
are the v6 and 2.7 deisel gearboxs compatible??
albundy
Rolly Polly
Re: terrano gearbox question
Post by albundy »
I think from memory no, could be wrong though, but you could check by going to a car yard with both and checking the VIN plate.
AL
Safari Swb
Post by Safari Swb »
the bellhousing patterns are different.
89 safari swb-4.2 auto..for sale
96 safari swb-2.8t manual..stock
Ryan
Post by Ryan »
oh ok..... i have a 5speed gearbox and everything for a conversion from auto to manual if anyone is keen.....
darinz
Post by darinz »
And I have a V6 5 speed etc availa ble as well, but mine is up north.
Nav2NV
Post by Nav2NV »
the gearbox them selves are probably the same, check the tags on the right side wheel well if the transmission code is re4ro1a (i think) if so,do a quick measure on the bellhousing and see if they can be swapped over.
it was the case for my 2wd navara.
long
Post by long »
Rayn hi no they r not but theres no reason you couldnt make up an adaptor to get it to fit.
Gary
Ryan wrote:are the v6 and 2.7 deisel gearboxs compatible??
Terrano TD 2.7 and a ssangyong Rexton
long
Post by long »
Ryan giday again i have here on disc the patterns if you want me to send you a copy of them let me know but they dont give mesurements for them but you would get the idea of how much they differ.
Gary
