CB (AM/HF) Aerials/Antennas
Find the best deals on tools and supplies here.
Moderator: Vendors
CB (26mhz HF AM)
Note these are not the PRS 40ch, these are the ones the truckers use)
1200mm CB Flexi $50
900mm CB Flexi $45
Springmount bases recommended for these larger ones, these are the fast fit type which the cb connection doesnt require crimping or soldering (or the larg connector to push thru your firewall) pricing up soon
L Brackets are also recommended $10-15 depending on size
smurf182
Re: CB (AM/VHF) Aerials/Antennas
Post by smurf182 »
FYI, 26MHz is in the HF band, not VHF. VHF is 30-300MHz
Cheers, have updated....
fweddy
Re: CB (AM/HF) Aerials/Antennas
Post by fweddy »
Jerry - will that spring mount work for a PRS aerial too?
taz01
Tazzles
Post by taz01 »
the small prs antenna works bloody well was parked down gully getting firewood in rallywoods and talking to stinky who was just at bottom of the haywoods, hutt side
WARNING:
LIFTED
Post by LIFTED »
Just brought a GME TX2700 from Dick Smith 26MHz CB.New to the world of radio i wanted some contact with others incase of trouble and if im out with other radio users.Friend tells me nobody uses AM now and I should have got UHF? or fm,Whats the go is he correct?
89 SWB Patrol Lpg/petrol 5spd, body lift, spring lift,headers & high flow,Custom front bars 9000lb winch and 4x100w hella spots,custom rear bars and stainless fuel tank,Hankook 35/12.5/15x10 rims.
wisard2
Post by wisard2 »
No, he is not quite correct. While most clubs use uhf (prs) radios, a lot of us use both, as they each have their own advantages and disadvantages, and cb is also good for on road communication with trucks etc.
92 swb Pajero ute. 3 litre V6 manual. 33" Mud wranglers, Diff breathers, Snorkle, 9500lbs electric winch, Rear diff lock, CB & PRS radio's.
Heath
Post by Heath »
Ive got a 26MHz cb and intend to update to PRS at some stage, but will be running both of them at the same time. They both have their uses and you can be sure if you only take one then everyone else with have the other type. :D
Let me know the prices Jerry for those mounts might be up for a couple. I assume they work with PRS aerials too (maybe wont need the spring though.
muddyhilux
Post by muddyhilux »
hey jerry,no huge expert on these things but kinda kno the longa the furtha the signal?what sorta range wil i get with the 1.2 over sand dunes?ie say one end of 90 mile to the other?or less?do you you any longer than 1.2m?cheers mate
Twodiffs
Post by Twodiffs »
Anyone got an update for this?
I went to Dick Smith recently and they no longer stocked aerials :shock:
I'm after a new uhf and am aerial - years ago I got a wire aerial from Dunedin which was brilliant...was about 1-1.2m and for the AM iirc.
Still got some UHF in stock wire and flexi ones, Can do CB ones as well, pm me
Twodiffs
Post by Twodiffs »
pm sent, thanks mate.
tallsam66
Post by tallsam66 »
If your buying a PRS make sure its one that can be upgraded to 80 channels.
Twodiffs
Post by Twodiffs »
tallsam66 wrote:If your buying a PRS make sure its one that can be upgraded to 80 channels.
Nah mate...Had my uniden sundowner uh100 for nearly 10 years, probably use it until it dies which it hasn't yet. It surprises me sometimes, was leading a night trip into the Macaulay years ago and I was talking to the guys already at the hut when we were still beside Lilybank. There are some on Tardme but you get what you pay for so I'll wait and see what Jerry has.
Return to “Winches, Accessories, Tools and Supplies”
