95 Terrano ball joint boot
Hi all, while I was giving the old girl a dose of oil and grease, I noticed one of the boots on the drivers side outer ball joint has a tiny split in it. Does anyone know where I can get a replacement boot from please?
Ph 0212078472
Ph 0212078472
Re: 95 Terrano ball joint boot
Hey
Might be easier to buy the whole joint, from memory they aint that expencive, and then keep that ripped joint for a spare.
Cheers Daniel
Cheers Daniel
Hey just try repco mate
try bnt
Thanks peoples.
Ph 0212078472
Ph 0212078472
If you are going to replace the hole joint get the ones frm BNT. I used repco ones once and had to replace both for the next wof (6mths) got BNT ones and last 4 WOFS then sold terrano. They are a common failure apparently.
meatc wrote:If you are going to replace the hole joint get the ones frm BNT. I used repco ones once and had to replace both for the next wof (6mths) got BNT ones and last 4 WOFS then sold terrano. They are a common failure apparently.
can you remember how much the bnt ones were?
Ryan wrote:meatc wrote:If you are going to replace the hole joint get the ones frm BNT. I used repco ones once and had to replace both for the next wof (6mths) got BNT ones and last 4 WOFS then sold terrano. They are a common failure apparently.
Its been a couple of years since I did the last one but I think they where about mid $30s. Pretty sure they where cheaper than the Ripco ones.
At this stage I only need the boot, not the whole caboodle, thanks.
Ph 0212078472
Ph 0212078472
- mud_slinger
a place in hornby sells the boots can not remember the company name
ps good to se ya on sunday and cheers for the fruit bursts and minties
needs more curry
0272593533
0272593533
