Hilux Ute rear recovery hook
Posted: Sun Apr 26, 2009 5:19 pm
Hi, the rear of my Hilux has a removable to bar (see pics). Would this be sound enough to hold a recovery hook (do not want a lecture from Jerry you see!!!)... build a straight bit of thick steel and drill couple of holes for hook and rear holding pin?
http://btd.co.nz/under1.jpg
http://btd.co.nz/under2.jpg
http://btd.co.nz/tow.jpg
(sorry pics are below size limit but still not like them)
If so, any engineering type folk wanty give me a quote
30mm thick (currently two welded together - bottom slimmer than top)
64mm wide
309mm long (locking pin hole centre to current bash plate) will need length to allow recovery hood to be added to this figure.
approx 22mm (dia) for locking pin hole
Hope the above makes sense
cheers and tia
W
64mm wide
cheers and tia
W
