Surf 90 Gearbox breathers
Is anyone familar with where abouts they are? Ive tried finding them with no success.
"If it aint broken let me @ it!"
Breather on top of gearbox!
Gidday Andrew! How's it? You have to remove the gearlever trim and rubber boot so you can see the top of the gearbox and the breather is to the left of the high/low ratio lever! I've tubed mine up to the top of the inside of the gearlever boot! I figure if I get water in the cab it's time to check the gearboxoil!
