safari starting
For all Nissan related topics
allmud
safari starting
Post by allmud »
every morning when i try to start my safari ( 4.2 desiel 5speed) its like it has a flat battery turns over verry slow then speeds up
im thinking starter motor
annybody have anny better idears ?
haynzy
Re: safari starting
Post by haynzy »
shoulda kept to toyota
allmud
Re: safari starting
Post by allmud »
haha na
u and fj40 ned someone to pull out when we go out 4x4
PR
In the crap again
Re: safari starting
Post by PR »
Take the starter out strip it down and give it a good clean out :mrgreen: proberly got mud in it :wink:
(021) 02388443
fj40
Re: safari starting
Post by fj40 »
allmud wrote:haha na
:lol: to dam heavy to pull that thing out :lol: :lol:
its not how big the 4x4 is its how angry the diver is
safaripete
Re: safari starting
Post by safaripete »
it will be the batteries bud they need a dam good charge up the starter has been done also the altinator
allmud
Re: safari starting
Post by allmud »
sweet will charge in the weekend
KiwiMoose
Re: safari starting
Post by KiwiMoose »
A few weeks back my safari was doing the same thing, getting slower cranking then one day it wouldn't even start. Spent a while cleaning some corrosion out of the battery terminal contacts then coated them in vaseline. Started up no worries after that.
safaripete
Re: safari starting
will drop ya round those bits too
allmud
Re: safari starting
Post by allmud »
sweet thanks
i have the paperwork here for the cruiser as well
do u still have a copy of the wof sheet
safaripete
Re: safari starting
i do somewhere
but will need to be completey redone as tha wof i went for was in january haha
allmud
Re: safari starting
Post by allmud »
well got the batteries tested to day one was rooted got a new one
thay tested the charging its charging ok made new earth leads
next job will be pulling out the starter and cleaning it out and geting it checked
startd better now with the new bat but still like a dead bat every 5th or so start
safaripete
Re: safari starting
which battery was buggered??
haynzy
Re: safari starting
Post by haynzy »
best practise would be to replace both as although the other one may test well it will very quickly damage the new battery and severly shorten the life of both batterys.
allmud
Re: safari starting
Post by allmud »
the left hand side bat was stuffed
Re: safari starting
I got away with replacing just one
haynzy
Re: safari starting
Post by haynzy »
coxsy wrote:I got away with replacing just one
quote of the day "I got away"
in any multiple connected battery setup any cell that has less capacity than the other will cause the other cell to over compensate
Re: safari starting
still starting and running :D maybe both were fairly new to start with
