laser on 870
laser on 870
just got a laser for my 870 pump action which came with mounting bracket was hoping to mount to the mag camber but the mag camber is too big so have to bolt onto the barrel... i cant see anything wrong with this but i thought i'd check before i fire it just in case ! ?
- Moriarty
Re: laser on 870
107
mag camber? do you mean the cartridge CHAMBER?
is it a screw-on mount, or a clamp-on mount?
can you take photos and post em up here?
wildplumdx wrote:just got a laser for my 870 pump action which came with mounting bracket was hoping to mount to the mag camber but the mag camber is too big so have to bolt onto the barrel... i cant see anything wrong with this but i thought i'd check before i fire it just in case ! ?
Re: laser on 870
ahhh yes sorry just read what i wrote lol yes the shell chamber , clamp on mount thanks
PIC HERE! http://i2.photobucket.com/albums/y33/wi ... aser-1.jpg
- Moriarty
Re: laser on 870
wildplumdx wrote:ahhh yes sorry just read what i wrote lol yes the shell chamber , clamp on mount thanks
Looking at the above photo, with that being a trombone gun, I cant see you fitting it any better than you have done. You are putting a laser dot on a target? how does that work on ducks??? I can see that it would be possible but unlikely to target a clay bird, but a duck? or a quail?
Seriously, though, that side mount gives you a normal sight picture for snap or running shots and the laser-dot for a more deliberate shot
B
Re: laser on 870
nah nah its hardly a duck shotty too short, use it for possums and rabbits, all i wanted to know is its safe to mount it this way as i couldn't see why it wouldn't be but better to be safe then sorry!
- Moriarty
Re: laser on 870
It's all good, mate. for a scattegunwith a max effective range with slugs of around 100M and 40M with pellets, the offset position is ok. where it a rifle, it would not work at all well for tack-hole accuracy, but your application, not a problem.
B
B
