daihatsu rugger fwh wanted
hi guys am after a fwh for a rugger for a mate .can any one help plus where is the best (cheapest ) place to get a kingpin /seal kit for the same vechicle cheers sig
Re: daihatsu rugger fwh wanted
BNT for the kingpin/seal kit, as for the fwh... wgtnnewbie has some and he doesn't use it so you should be safe to take them
Colins motors ask taz
- skid
- Tyre Man
suzuki1k wrote:BNT for the kingpin/seal kit, as for the fwh... wgtnnewbie has some and he doesn't use it so you should be safe to take them![]()
au contraire my learned friend
he thrashed the faaark out of the little beast over the weekend
impressed us all
as for the parts
ASK THE DORKY KID NAMED JERRY
he used to own one
We found an Asin hub from a liteace 4wd was the same. For a JizzBucket (Blizzard) that is.
Tim.
Oh and if you tear an axle in half, they use the same dia and spline count as a Corolla or Corona axle. Go figgure.
Tim.
cheers for that will send him up to pickapart to troll there liteaces
from memory the diffs on the old rugger looked different to tardbe's blizzard, they may be different, the daihatsu delta may be similar so they may have the same diffs.....
Feroza/Rocky/F300 diffs may be worth a look in case the hubs are the same but again they may be different....
Be careful if looking up parts catalogues as you have:
F300 (NZ New Feroza, Import Rocky, also known as Sporttrack)
Rocky (NZ New Rocky, Import Rugger, also known as Fourtrack)
may be some info on these forums too
http://www.daihatsu-drivers.co.uk/forum
http://www.warfs.org/
