Page 1 of 2
8th - 9th May 2009
Posted: Fri May 08, 2009 2:43 pm
by Dr_PC
Stuff work had enough of computers going to load the buggy on the truck ready to go to the workshop in the morning and finsh putting front spacers on and repalce bent front panhard rod, Still raining
Re: 8th - 9th May 2009
Posted: Fri May 08, 2009 6:04 pm
by coxsy
well for my weekend fit modded tow bar, gearbox spacers, then go with son to look at another fj40
Posted: Fri May 08, 2009 6:15 pm
by lilpigzuk
Dr_PC wrote:Stuff work had enough of computers going to load the buggy on the truck ready to go to the workshop in the morning and finsh putting front spacers on and repalce bent front panhard rod, Still raining
sweet, come down for interclub on sunday at tuoheys place for a play - just down the road
Posted: Fri May 08, 2009 8:14 pm
by tintin
getting a bit done, project tintin is looking something like this at the moment
Posted: Fri May 08, 2009 8:32 pm
by mudzilla
Look'n good ,, Looks better with the Bling wheels on tho
Posted: Fri May 08, 2009 8:34 pm
by Jafa
Cmon Qentin, get that 3rz goodness in it already!
Posted: Fri May 08, 2009 8:40 pm
by tintin
Jafa wrote:Cmon Qentin, get that 3rz goodness in it already!
good things take time, you know that
Posted: Fri May 08, 2009 11:20 pm
by fj40
tintin wrote:Jafa wrote:Cmon Qentin, get that 3rz goodness in it already!
just put a 350 in it
Posted: Sat May 09, 2009 4:13 pm
by coxsy
left my cell on the bonnet of the safari bye phone
Posted: Sat May 09, 2009 4:58 pm
by xj
coxsy wrote:left my cell on the bonnet of the safari bye phone
Lost one like that too, and lost another up thompsons two weeks ago too... somewhere up the rock climb.
Gee i love work phones.
Back to the topic at hand...........
Popped the 15mm spring spacers in the front to level it up, and re-aligned the front diff. Noted that even after the last wheel alignment that it was toe-ing out bigtime. Pulled out the trusty tape measure and it was out by 30mm, so remedied it by way of a back-yard wheel alignment.
Also noted that the front lower control arm castor correction bolt on the left was loose, and not just a little loose. Something wrong there, when the nut is tightened to the bolt she tightens right up, but the bolt can still rotate, hence cocking up the castor. Washers are where theyre supposed to be, its got me buggered.
Didnt even get to looking at the skid plate today.
Posted: Sat May 09, 2009 7:50 pm
by wopass
widened my trailer a bit so i can get the missile on it without having to change the frickin wheels...
tomorrows job is load the 40 onto the trailer to make sure its ok and see where the ballance point is so i can then start making the front section for spare wheels etc and make a front tie point.
Posted: Sat May 09, 2009 8:04 pm
by monstr
Spent the day replacing front brakes,wheel bearings etc fitting new winch rope,got the isolating switch wired up ,cleaned radiator ,still have 101 jobs to do before Northland ,hopefully will get it all done by Wed/thurs night
Posted: Sat May 09, 2009 8:05 pm
by haynzy
well put the new juke box in me prado f*&k what a mission still now can at least listen to the rock
Posted: Sat May 09, 2009 8:18 pm
by gimmemud
monstr wrote:Spent the day replacing front brakes,wheel bearings etc fitting new winch rope,got the isolating switch wired up ,cleaned radiator ,still have 101 jobs to do before Northland ,hopefully will get it all done by Wed/thurs night
What ya gonna do with the old rope?
Posted: Sat May 09, 2009 8:25 pm
by J_Dub
veiwed a 4x4 with me bro today that hes looking to buy.
88 rangie recoed v8, front and rear bars, winch, factory locker, 31" muds, snorkel.
$3k, thats alot a 4x4 for ya money, bloody good value i recon, mite need a few things here and there but for that price a tidy v8 4x4 with winch and bars, its gota be a good thing
Posted: Sat May 09, 2009 8:45 pm
by muddymatt
J_Dub wrote:veiwed a 4x4 with me bro today that hes looking to buy.
Sounds like a good buy at that! Query on the factory locker tho' that will be the centre diff lock as to my knowledge no Rover left the factory with a axel locker till the current shape Disco3.
Muddymatt
Posted: Sat May 09, 2009 8:53 pm
by monstr
gimmemud wrote:monstr wrote:Spent the day replacing front brakes,wheel bearings etc fitting new winch rope,got the isolating switch wired up ,cleaned radiator ,still have 101 jobs to do before Northland ,hopefully will get it all done by Wed/thurs night
Sorry mate Wayne (Vvega) has already put his name on it ..Steve
Posted: Sat May 09, 2009 9:01 pm
by LJ71simon
haha i got stuck at the ymac today in the mega mud part was a shocker all 4 wheels were off the ground, THANKS to the people that helped get me out of the mess i was in, then when towing it out she almost tipped right ova, prettymuch on the side as it was, as a result i have lost the hub off drivers side, the mud was up to the sidestep lol.. bit of fun, now have to fix her up
by safaripete
removed the half cab from the cruiser and put the soft top on
an bolted the seats down properly
Posted: Sat May 09, 2009 9:06 pm
by LJ71simon
bolted the seats down properly LOL always helps? upload some pics of softtop
Posted: Sat May 09, 2009 9:17 pm
by safaripete
LJ71simon wrote:bolted the seats down properly LOL always helps? upload some pics of softtop
will do once i finish the front mounts for it and finish welding up the roll cage
Posted: Sat May 09, 2009 11:11 pm
by J_Dub
muddymatt wrote:J_Dub wrote:veiwed a 4x4 with me bro today that hes looking to buy.
Muddymatt
yip u are right, and i was gona question that, what exactly is meant by a cetre diff lock?
Posted: Sat May 09, 2009 11:25 pm
by muddymatt
J_Dub wrote:muddymatt wrote:J_Dub wrote:veiwed a 4x4 with me bro today that hes looking to buy.
Muddymatt
Unlike most Jappa 4X4 Rangies are permanent 4WD with power transferred to the end with the least grip just like a standard open axle diff. You can lock the centre diff to force power to both axles. Works in high and low range too.
Hope that helps.
Matt
Posted: Sun May 10, 2009 7:50 am
by kaney
finished work sat at 8am then went to the events club club day at ricks in Amberly, was an awesome day...realised i need to modify the fiddles as cant select 1st and still use them. and have a strange noise coming out if the front end...sounds like a cv- will pull apart today and find out. left a bit after lunch as had work last night as well.
Posted: Sun May 10, 2009 9:33 am
by Pedro
fitted diff head to new cruiser housing in the rear, reassembled hub, axles and rear diff cover swapped drive flange o diff over to hilux, so no need to modify drive shaft, now gotta pull front diff and change from 4.3 to 4.1 ratio, then fit winch, wire it up, make gear box for back, grease it, oil it, check it and then go and wreck it again!!!! 2 weekends to TR so no pressure!!
pedro
Posted: Sun May 10, 2009 11:31 am
by wopass
truck fits on trailer
finaly
still to finish floor and ramp and spare wheel holders but the main bit is done and is now usable
Posted: Sun May 10, 2009 1:25 pm
by mercutio
wopass wrote:truck fits on trailer
finaly
looking good
so what is the daily hire rate
Posted: Sun May 10, 2009 1:39 pm
by wopass
mercutio wrote:looking good
to you mate a box of tui or 20 buks
Posted: Sun May 10, 2009 6:29 pm
by skid
Early Saturday morning, me and Sadam headed into his hut in the bush
drove as far as the river and parked up the 80 and got a lift to another hut,
about 6 hours later we fell out the door and staggered, crashed, fell down and eventually made it to Sadams hut
woke up this morning to find all sorts of cuts and scratches on our legs, went for a walk down to the river about 7am and spooked 2 deer less than 15 metres away from me, dammit, always happens when you don't have a rifle with ya, they were slow too, would of been heaps of time to try and get 2 shots off and have 2 hanging in the shed, oh well next time maybe.
walked back down the river this afternoon to the 80 and drove out
great weekend
excuse the grainy pics ( cellphone )
Posted: Sun May 10, 2009 6:48 pm
by mercutio
wopass wrote:mercutio wrote:looking good
nice one i'll keep that in mind pity i got nothing to tow it with
i didn't get up to much but i did find the time to get this
should come in handy in yoricks shed till i get my own decent shed
