anyone turbo'd a 1fz fe???
Posted: Wed May 13, 2009 7:59 pm
by swampa
anyone turbo'd a 1fz fe??? thats the question, i know they go good, and there are kits available in oz,fuel consumption is around 22 to 25l per 100k's at best so cant get much worse, just wondering if anyone in little ol nz has?
Re: anyone turbo'd a 1fz fe???
Posted: Wed May 13, 2009 10:21 pm
by GotFlex
I know of a local guy who is twin turboing his dx Corolla 1982 with a Lexus V8,
Hes had the lexus for a while and its evil
Let alone stapping 2 turbos to it
ill try get sum pics etc
Posted: Wed May 13, 2009 10:55 pm
by Engineer
GotFlex wrote:I know of a local guy who is twin turboing his dx Corolla 1982 with a Lexus V8,
a 1fzfe is the factory landcruiser 4.5litre petrol engine not a 1uzfe close though..btw swampa has just sold his supercharged 1uzfe hilux so he knows what forced induction does to a lexus
ryan
Posted: Thu May 14, 2009 6:45 pm
by GotFlex
oh heck, sorry, hahahah
Posted: Thu May 14, 2009 8:08 pm
by NJV6
swampa wrote:anyone turbo'd a 1fz fe???
DO IT!!!
but then buy your wife a nice car and don't sell it!!!
Posted: Thu May 14, 2009 9:10 pm
by mar4les
turbo !!! i agree with glen, JUST DO IT!!!! and don't forget the big intercooler in front ,two go with turbo it be no snail!!!!
Posted: Thu May 14, 2009 9:25 pm
by swampa
allready have, the process has begun, will be a slow and expensive exercise, i can get a manifold already setup, need to find an outfit that i can trust to do the rest, any where in godzone
this guy drags an old crown, he has some goodies for sale, this ad was 2 year old
Turbo 1FZ-FE Engine Package
CONDITION:
Excellent (see extra-info for specifics)
REASON FOR SELLING:
I am currently building a 1000+hp 1FZ-FE and am selling off my current set-up that I have been developing over the past 5 years.
PRICE AND PRICE CONDITIONS:
$9500 Aus
EXTRA INFO:
Package Specifics
ENGINE
Toyota 1FZ-FE
Standard valves
Ivan Tighe performace camshafts (268 deg duration)
Mild clean-up to bowls
Head is O-ringed (Rhemac engineering, Adelaide)
Reduced compression via modified combustion chambers
Upgraded valve-springs to cope with 20+ PSI boost
Custom ARP head studs
Standard rods, crank pistons
Motor is all fresh-
Rings
Bearings
Valve-stem seals
Head gasket
valve-seats
All professionally assembled.
Motor will need to be run-in when fired first time.
External components
Cold-side
100 series landcruiser stub manifold,
modified to run 12 injectors
2x factory fuel rails
2x factory pressure regulators
12 injectors, 6x440cc, 6x550cc
Custom upper plenum with bell-mouth floor plate
Standard throttle-body (65mm)
Hot-side
Custom turbo manifold, split-pulsed runner type
Dual Tial 38mm external wastegates (7psi springs)
Garret GT42 plain bearing turbocharger, rated to 1000hp, modified GT45 1.22 rear housing
(as new condition-just refreshed by ATS here in Adelaide and has not been used since)
Uni-filter 6 inch air filter + 5 inch rubber elbow to connect to turbo
V- band + 4 inch stainless dump pipe
Teflon Braided oil feed + drain lines.
Standard distributor + Top Gun ignition leads
A single Bosch 044 fuel pump is included, which will feed enough fuel for just on 400rwkw.
HP ability
This motor will comfortably and reliably produce in excess of 400rwkw@23psi boost.
To use this motor, you will need an aftermarket EFI computer. Autronic, Motec, Haltech are suggested, along with a Crane Hi-6, or similar CDI system.
Posted: Fri May 15, 2009 6:46 pm
by mar4les
it reads grate!!!i like the sound reliably and comfortably when taking about big hp !!!! sound like it be happy'er at drags .
Posted: Sun Oct 31, 2010 4:28 pm
by 79series
Posted: Sun Oct 31, 2010 6:06 pm
by You Get That
What vehicle is this going on?
(That 79 is beautiful
Posted: Sun Oct 31, 2010 7:17 pm
by 79series
You Get That wrote:What vehicle is this going on?
thanks mate ,
the turbo and all is on my motor in my 79series
Posted: Wed Jul 20, 2011 8:40 pm
by Justin W
Hey man, how'd you get on turbing the 1fz-fe? I have one in my 70series cruiser and wanting to know if its not to bad to do?
Posted: Sat Sep 24, 2011 11:53 pm
by 79series
Justin W wrote:Hey man, how'd you get on turbing the 1fz-fe? I have one in my 70series cruiser and wanting to know if its not to bad to do?
Off road is great plenty torque and power ,
On the road is just a fun , specially smoking patrols,
I've had it running for nearly a year now with no engine problems , even out bush on 40deg days last summer the temp gauge didnt budge,
What year is your 70 series bud?
Fuel Eco with turbo and 35s is the same as when it had no turbo and 31s
Posted: Sun Sep 25, 2011 7:37 am
by vinceparts
Posted: Thu Oct 17, 2013 11:47 pm
by 79series
7-8 psi
garret gt35/40
efi hardware toyota 450cc injectors direct fit
Walbro in tank fuel pump
haltec ecu plug n play
lpg injection as well
fpr
Now low mount turboglide manifold
3" exhaust
front mount intercooler
Back to internal wastegate
It pulls past 180kmh no problems, (in a landcruiser scary i know)
