Auto and Manual diff's
Posted: Sat May 16, 2009 9:30 am
by SV1K
Hi,
I have another Safari that was an auto and I am going to do a motor and gearbox swap I have a question about the diff ratios though. I also have a little something for the front but want to make sure that I am not wasting time.
Is a difference between diff ratios with Auto's and Manual's?
The tag on the truck reads : Trans Axle RE4R03A HG41
I have heard that there is a difference but am unsure.
Reece
Re: Auto and Manual diff's
Posted: Sat May 16, 2009 9:43 am
by skid
suzuki1k wrote:Hi,
Reece
does one tag read different from another
I may be wrong, but that tag reads 4.1s to me, so wots the other tag say dude
Posted: Sat May 16, 2009 9:47 am
by SV1K
Posted: Sat May 16, 2009 10:05 am
by curly12
The petrol and desiel's had different ratios
Posted: Mon May 18, 2009 8:54 pm
by darinz
HG41 means it is an 'H' series centre.
'G' means solid axle.
41 means it is a 4.11 ratio
Most are 4.11 except petrol auto's are 3.9, (HG39)
leaf sprung and budget models are 4.3, (HG43)
2.8 desiel and 3.0 petrol are 4.625 (HG46)
And then there are always a few odd balls that don't fit the normal specs.
Posted: Tue May 19, 2009 8:18 pm
by flyingbrick
These 4.62 diffs
I've seen them on 4wdbits.. for 1400ish for front and rear..
Do people just buy them because its hard to find 2.8 diesels being wrecked?
Posted: Wed May 20, 2009 10:49 am
by darinz
Yip. 4.6 diffs are quite rare.
Posted: Sun May 24, 2009 12:59 pm
by Safari Swb
wont terrano diff centres work?? hg46
Posted: Sun May 24, 2009 2:00 pm
by SV1K
Posted: Sun May 24, 2009 4:03 pm
by coxsy
in the front yes not the back as back diffs are bigger
Posted: Sun May 24, 2009 9:04 pm
by Shane
LSD carrier from terrano rear well fit in to front GQ diff head,I beleave the gears from the terrano
wont fit the GQ diff head.
My friend chased this up last week(I though the D21 rear would fit)and the gears not close at all according to him.
Shane
Posted: Sun May 24, 2009 9:09 pm
by flyingbrick
You just use the terrano LSD center.
Use the safari carrier/gears
Posted: Mon May 25, 2009 10:39 pm
by darinz
Terrano R&P do fit with a small amount of machining. It has been done before.
Posted: Tue May 26, 2009 9:25 pm
by Safari Swb
so how much would a set of 4.62 diffs be worth, i have a set out of my 2.8 safari that i may be getting rid of if i swap the motor out
Posted: Wed May 27, 2009 9:01 pm
by darinz
Why would you egt rid of the 4.6's if you are keeping the truck?
With 35's it is the same gearing as 31's and 4.1's.
