The 1.25inch body lift went in, the engine mounts went up 1 inch (and held over the weekend too thankfully) and it appears the pan will lift up around 2 inches. Those figures just dont sit well in my little brain.... however, according to the many websites ive looked at, and different designs ive seen, it should be sweet.... after all if the Americans do it, it must all fit together ok.........
Any-hoo.... tonights pics below and more progress pics to come. All going well i should just about have it on tomorrow night. Which will give me enough time to modify the stock one before QB weekend if this all goes pear shaped.
The old and the in progress
Box section added
Side holes marked
Height comparisons
The centre secion will be built up a bit though. The pad will sit directly on the plate, and the threads will stick straight through, therefore a small section will be built up around the square created by the four threads, opposite to how they sit stock, to protect the threads and nuts..
Only doing it this way, as, again, im concerned about having to lift the tranny any higher. Hopefully it works out.
Tomorrow will tell
