Oxygen sensor
For all Suzuki related topics
suzookyman
Oxygen sensor
Post by suzookyman »
hey all, can anyone tell me if you need to
have an oxygen sensor and what it is that it
does.It is not connected at the mo and is on
a 1989 ecudo
cheers Al
1rugger
Re: Oxygen sensor
Post by 1rugger »
as far as i understand when the computer is in closed loop mode it uses the O2 sensor to fine tune the fuel injectors to get the right air/fuel ratio. so you will be running slightly rich and use a bit more fuel with it disconnected.
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
Return to “Suzuki”
