Terrano Wheel bearings
Ive got a terrano d21 1992, problems have arisen latley that being sometimes you get a horrid squeal from the front right wheel, does it more often in the cold night, now question is how hard is it to disasememble the automatic hubs on it, any help would be apreciated
Got a 94 widebody. Have just finished replacing all three bearings on front lefthand side(inner,outer and needle roller bearing for shaft). If you have some basic mechanical knowledge and can follow instructions, easy as. You will also need the right tools. You can get the manuals from your local library. I have manual hubs, but the book instructions look pretty easy for the auto. Are you sure it is the bearings? Not brake pads sticking as I once had on right side?
Al
Al
