wet jeep
Re: wet jeep
A bit more details/specifics is helpful before anybody can help you. As a precaution, if the Jeep (which could mean many many models) has been under water, it is advisable to change the fluids as quickly as possible. Auto transmission does not like water. Diffs might be marginally more forgiving, but engine and auto trasmissions do not like water mixed in oil.
Change the oils and filters and replace with proper oils and see what happens (this is if you have not done damage already).
Re: wet jeep
its a 99 cherokee. you put it in reverse and it goes forward and nuetral it goes forward
Re: wet jeep
Is oil on dipstick for tranny milky or smells burnt? If yes, its got water or got burned by excessive heat. Both are bad for the tranny. Changing the oil and filter on tranny will help.
I don't have much experience of Cherokees, you might have to wait for XJ owners to chip in.
Re: wet jeep
yea the trans oil is milky but engine is all good. gonna r4eplace oil and filter tomorro
Re: wet jeep
orange wrote:yea the trans oil is milky but engine is all good. gonna r4eplace oil and filter tomorro
In that case I would suggest a proper flush of the entire tranny. Just changing the oil won't get all the old milky oil out of the system.
Re: wet jeep
yea we gonna change it and run it for a day then change it again
Re: wet jeep
orange wrote:yea we gonna change it and run it for a day then change it again
when i took my last surf for a swim, i got the trans flushed, would recommend this cause thats the only way to fully clean all the internals.
think it took 12 litres before it was fully clean, or maybe it was 8... $350 later
was real bad, damage was already done, but i drove it for a week or 2 before flushing i
Re: wet jeep
oh yup cheers boss ill tell my mate asap
Re: wet jeep
if theres water in it, youre screwed. Theres a glue in there that is water based that holds the clutch linings on. (that is assuming the TJ and XJ's are put together the same. Ive had two TJ trannies chopped due to water. First one was fully submerged and lasted about 5 mins. The second one had a small water leak from the radiator into the tranny cooler and buggered the whole setup.
When you say that it goes forward, do the forward gears engage and change at all? If the reverse is going forward and only forward, and the same for neutral(and im picking you were going forward when it got drowned) then i would suggest that you need a trip to the transmission shop with about $2,500 in your hand.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Re: wet jeep
xj wrote:First one was fully submerged and lasted about 5 mins.
did it look anything like this?
Re: wet jeep
yerp, that was a fine effort to be sure.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Re: wet jeep
yeah once you have water in there ... there fucked... unless you flush it .. THEN RIGHT THEN
must remeber to put a extended breather on my trans
Kiwi4x4
Re: wet jeep
Yo orange, how did it go?
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Re: wet jeep
lol it didnt my mate justr parked it up for now. i dunno what hes gonna do to it now
