How much lift for 35's??
CSJ
Post by CSJ »
hay all
Just wondering how much lift i will need to fit 35's ive already got 50mm lift. Or whats the biggest tyre that will fit?
Cheers All
muddyplumber
Spring Free
Re: How much lift for 35's??
Post by muddyplumber »
what sort of toyota do you have? i managed to get 35 wranglers under my prado with just a 50mm body lift n bit of guard chop, was tight tho. fitted 35 mudzillas under my cruiser with 50mm body lift and 2" spring lift with raw shocks
CSJ
Post by CSJ »
Ive got a 87 D/C i think its already had a guard chop theres so much room with 31's. After market guards i think. Ive got EFS 50mm shock absorbers and 50mm spring lift.
Will the shocks handel another 50mm lift? I know ill have to put extended bake hoses.
The plan is to have 35in mud tyres and standard road tyres for gettig around on.
thanks
haynzy
Post by haynzy »
Really you need to shift the front axle forward about 50mm as with a 50mm body lift my 33's would rub,
I have a 3in susp lift and 40mm body and I easy clear 37's but have moved the axle forward
rxsmiddy
Post by rxsmiddy »
a friend of mine ran a 60mm body lift and a 2inch susp lift and fitted 35s easy, think his was a 87 d/c
CSJ
Post by CSJ »
Ohk thanks guys.
Can you tell me where i can get a 50mm body lift kit. is it the shackels?
And how to move the axel 50mm frwd?
And will my shocks have any trouble with the lift?
Im all new to this modifying stuff but my dads a+ mechanic so no troubles for him.
Thanks Cam
muddyplumber
Spring Free
na the lift blocks are different to the shackles. the lift blocks go between the chassie and body. there will be 10-12 bolts that hold them together, you un-do these and jack the body up slightly and insert the spacers,you will need longer bolts aswell. most 4x4 places sell the blocks
CSJ
Post by CSJ »
ok seems alright is there any mods after you lift the body?
Bulletproof
Post by Bulletproof »
CSJ wrote:ok seems alright is there any mods after you lift the body?
If you lift the body there are a couple of thing to be mindful of.
1 Steering rod can pull out if you go too high
2 Radiator shroud will hit the fan
Cheers Richard
Never say die, up man and try
Smurf
Post by Smurf »
Mate everything you are asking is in the forums already, use the search function and have a read, its all there.
here is a start
http://www.offroadexpress.co.nz/Forums/ ... f=1&t=1453
chevrolux
Post by chevrolux »
and cos the gear stick is stupid and has that dumb bend in it you need to modify that hole too. found that out when i tried putting it in 5th lol!
CSJ
Post by CSJ »
awsome thanks for all input.
