Okies, so I have gone and bought me a nice shiny LSD for my Terrano.
It is a 4.6 ratio and mine is 4.8 so I will need to change the gearing. From what I understand it will be the crown that gets changed?
Is there anything else I should do or look at or do whilst the change over is done?
Terrano LSD installation
Ph 0212078472
Ph 0212078472
Re: Terrano LSD installation
Another question, is there a better brand of LSD oil to use, or is it all much of a muchness?
Ph 0212078472
Ph 0212078472
step by step instructions......
(STAGE 1)
pick up from my house
(STAGE 2)
INSTALL.....(YEA, YEA, REAL HELPFUL AYE)
failing that get ken to do it....
(STAGE 1)
(STAGE 2)
toymota thats stock standard.
Hi Pete, you will need to change the Crown wheel and Pinon, they need to be kept as a matched pair. I haven't set up a Nissan LSD but am lead to believe they are a better set up than the other brand ( that I won't bad mouth so I won't mention the T name ),
the LSD can probably be tightened up to make it more efficient, you will have to do a complete strip to change the R/P so a good look at the bearings and replace where necessary and a new Pinion flange seal. Any LSD oil will do. Check with Rick at 4WD acc , for a price to change and set up I know your very skilled but a Linesman can't be good at every thing
, you could find yourself,
UP THE POLE,
FITZY.
UP THE POLE,
FITZY.
Up the pole without a ladder eh Fitzy?
Think I will look at myself, it cant be that hard.
Kaney, will contact you tomorrow sometime, thanks.
Ph 0212078472
Ph 0212078472
Im used to run lsx90 in the old terrano pete. As fitzy said, heaps better then a toyota one: there I said it for ya fitzy.
albundy wrote:Im used to run lsx90 in the old terrano pete. As fitzy said, heaps better then a toyota one: there I said it for ya fitzy.
Thanks Al, hope to get it in in a coupla weeks as i'm off to Lake Daniels at the end of July, if I can get the truck sorted.
Ph 0212078472
Ph 0212078472
Thanks Kaney, big thumbs up to you.
Ph 0212078472
Ph 0212078472
