Largest Tyre Size for Hilux
Posted: Thu Jul 02, 2009 6:40 pm
by timmay556
Whats the largest size you can go on a standard height hilux (96 IFS)
I don't want to risk breaking anything nor rubbing etc.
Should I stick with 31*10.5*R15?
They would be on the standard rims.
Re: Largest Tyre Size for Hilux
Posted: Thu Jul 02, 2009 7:55 pm
by haydgq
timmay556 wrote:Whats the largest size you can go on a standard height hilux (96 IFS)
Jaffa's Hilux is standard height and he can squeeze on 40's.!!!
Posted: Thu Jul 02, 2009 8:21 pm
by Bulletproof
haydgq wrote:timmay556 wrote:Whats the largest size you can go on a standard height hilux (96 IFS)
I dont think that is the answer he wants. Jafa's truck is far from Std.
The real answer is probably 32s
Cheers Richard
Posted: Thu Jul 02, 2009 9:14 pm
by timmay556
Might be better to play it safe with the 31's?
Posted: Thu Jul 02, 2009 10:34 pm
by GotFlex
37s bro, just trim your guards out, its all good, keep that COG down, plus assuming you have a 2.4 diesel, you will never break anything!!
Posted: Fri Jul 03, 2009 12:03 am
by Steve_t647
You can go to 32's and if you are happy for a little rubbing you can "massage" a couple of seam's to fit 33's but they will rub at full flex even with the front torsion bars wound up a bit.
If you are only in rivers fishing then 31's will do, if in ruts following other 4wd's then I would try some 33's on for size (find someone with 33's and throw them on to see what will rub).
33's will also gear up the 4wd (make it more gutless) and will put the speedo out (low) so you may not want to take the leap after trying it out.
Posted: Fri Jul 03, 2009 7:19 am
by timmay556
GotFlex wrote:37s bro, just trim your guards out, its all good, keep that COG down, plus assuming you have a 2.4 diesel, you will never break anything!!
She's the 2.8lt.
Well I spose I could get the tyer shop to chuck on a 32 too see if she rubs and if not then go for em.
I don't mind gutless, I don't own a whizz bang twin turbow AWD toy. As long as she can do 100KPH on the highway I'm a happy chappy!
Posted: Fri Jul 03, 2009 7:58 am
by rokhound
keep the width of the tyre down and you will have less interferance issues. When you say a '96 surf, do you mean a KZN185?
Posted: Fri Jul 03, 2009 8:25 am
by haydgq
Bulletproof wrote:haydgq wrote:timmay556 wrote:Whats the largest size you can go on a standard height hilux (96 IFS)
Cheers Richard
Oh i really thought Jaffa's truck was standard and that was how they came from the factory, Damm ive been looking for that model in the brochures and have never been able to find it.
Posted: Fri Jul 03, 2009 8:30 am
by haydgq
rokhound wrote:keep the width of the tyre down and you will have less interferance issues. When you say a '96 surf, do you mean a KZN185?
It might have 16's on it so you could try a 265/75/16 they are some times a little higher than a 32/11.5/15 but not as wide so often dont catch on any body work or guards and tuck up nicely. I had that size BFG muddie on a standard height 96 185 surf and the tyre was actually a fraction taller than my 33/12.5/15 Wrangler MTR but narrow so it fitted nicely.!
Posted: Fri Jul 03, 2009 6:21 pm
by timmay556
no sorry, its a wellside hilux.
Posted: Fri Jul 03, 2009 7:37 pm
by Bulletproof
The Guy asked a serious question and if you can't give him a serious answer you are better not to say anything rather than make an idiot of yourself.
Cheers Richard
Posted: Fri Jul 03, 2009 7:43 pm
by J_Dub
Cheers Richard
cmon, wheres the sense of humour, the 2 laughing faces at the end of his post gave away he wasnt SERIOUS... maybe the idiot is the 1 whos getting his tits in a tangle.. reeelaaaaxxx maaaannnnnnn
Posted: Fri Jul 03, 2009 7:47 pm
by GotFlex
TRIAL AND ERROR ALWAYS WORKS
Posted: Fri Jul 03, 2009 7:58 pm
by haydgq
Cheers Richard
Yea i agree, Settle down and find a sense of humour and if you cant handle a few people having a laugh then stay out it and dont comment.!!
Posted: Fri Jul 03, 2009 8:46 pm
by timmay556
I was in two minds if the guy was serious, so I just had a look at that guys truck and it is quite a machine!
I've been looking at the Firestone Destination MT's. Have heard the new ones - not the old atx - are pretty good.
Posted: Thu Jul 09, 2009 10:46 am
by 4Munta
hey Guys my 1995 4Runner(ln130) is running 265/70/16 but the frount ones rub a little at full lock but could be fixed with different offset rims
Posted: Thu Jul 09, 2009 11:49 am
by hosehustler
a friend of mine is running 31's on a std KZN130 hilux surf and he tells me they just touch and no more, I would therefore suggest 31's are as big as possiable without modifications, any bigger and they will rub like mad especially off road
Posted: Thu Jul 09, 2009 6:04 pm
by rangimotors
i had 32 wranglers on my first kzn130, standard height and no rub lock to lock, touched the rear seam of the inner gaurd a couple of times off road but a hammer fixed that. I never measured them and suspect that they measured about a true 31 so im sure tim is correct.
if it makes you feel any better i just bought 36's for my hilux, there is no way they'll fit until i move the axle but i consider it a little like a girl buying pants a size to small to give her motivation..
