Page 1 of 2
4/5 july
Posted: Fri Jul 03, 2009 8:13 pm
by crazee
Thought i would start this weekend off fitted mud tyres to new truck after other one got killed
Re: 4/5 july
Posted: Fri Jul 03, 2009 8:18 pm
by snork
repairing the stuck winch
Re: 4/5 july
Posted: Fri Jul 03, 2009 8:23 pm
by wopass
gearing up for the RWC
Re: 4/5 july
Posted: Fri Jul 03, 2009 8:42 pm
by coxsy
taking part in a kids with cancer run on sunday with counties club and manukau club
Re: 4/5 july
Posted: Fri Jul 03, 2009 9:51 pm
by Robbiee
oh I can play too...
Fitting new shocks and changing all the oils in my MU, and trying to find that dam water leak still
Re: 4/5 july
Posted: Fri Jul 03, 2009 10:15 pm
by 91Rangie
My F-O-A shocks arrived from the states couple weeks back so will be mounting them
Re: 4/5 july
Posted: Sat Jul 04, 2009 8:30 am
by Dr_PC
Going to wash it after the run from 2 weeks ago and start removing panels doors etc to start the rebuild. Purchased Orbital Steering and RAM the other day for the rebuild, so going to keep patting it as I walk past
Re: 4/5 july
Posted: Sat Jul 04, 2009 10:10 am
by downunderxj
Went to VTNZ to get WOF for the jeep
Failed on 5 relatively minor things so will try to get them fixed.
One of them already while still in the carpark at VTNZ. He failed it because the rear lap seatbelt was jammed under the seat, so I folded the seat bottom forward, lifted out the belt and put it back
Handbrake adjustment, headlight alignment, seat retaining bolts and front bumper to sort now.
I had removed the two plastic end caps off the bumper, well Rallywoods kindly removed one and is looking after it for me, the other is in the garage. Already been through one WOF with only one on the front, now I get told it has sharp corners
So thinking that a piece of hose split down the length pushed onto each end should do the trick??
Re: 4/5 july
Posted: Sat Jul 04, 2009 1:02 pm
by surf_tomo
fitted snorkel to surf
Re: 4/5 july
Posted: Sat Jul 04, 2009 6:05 pm
by SmurfN
fitted maxitrac lifted springs in my yn60 surf. raised it about 3-4 inches as old ones were sagged
gay repco only had 2 u bolts so had to order 2 more in for pick up tuesday. need longer shocks also. managed to drive home from mates workshop with 1 u bolt in each side and the shocks on each side supporting diff. dodgy i know
after commy shocks to fit surf otherwise will be getting brand new maxitrac shocks...
Re: 4/5 july
Posted: Sat Jul 04, 2009 8:07 pm
by kaney
Re: 4/5 july
Posted: Sat Jul 04, 2009 9:11 pm
by gimmemud
Ooh know what that feels like.
Got the crap body off the surf today and cleaned the chassis real good, so gonna put some chassis black on it tomorrow. Also got the body off the donor surf.
Taking the engine off tomorrow and put it on the bench to inspect and hopefully fix.
Oh good times
Also got a yn60 surf body no canopy if anyone wants it. roof caved in a little bit cause wasn't too concerned with it when pulling it off.
Re: 4/5 july
Posted: Sat Jul 04, 2009 10:50 pm
by PR
Re: 4/5 july
Posted: Sun Jul 05, 2009 12:56 pm
by T-Boon
went up woodhill night trials last night, was pretty sweet, got pretty stuck a couple times in deep ruts, but got pulled out quite easy. well has to link 2x9m and a 6m snatch to get enought length...
Re: 4/5 july
Posted: Sun Jul 05, 2009 5:01 pm
by albundy
Warrant, reg, RUC, cleaned and regreased front wheel bearings, fitted new hubs, greased truck, new engine oil, filters, air cleaner, fuel filter, diff oils, gear box oil and tranny case. Sorted spares: alternator, cv, wheelbearings, axles, belts, etc and recovery gear, ensured snow chains fitted, for upcoming trip.
sharpened chainsaw
Al
Re: 4/5 july
Posted: Sun Jul 05, 2009 5:05 pm
by haydgq
Mounted a couple of batterys and fixed a coolant leak today
Then mounted my elec fan.!
Re: 4/5 july
Posted: Sun Jul 05, 2009 6:05 pm
by coxsy
when on this cankids run, heavy showers on the hunua hills wet clay tracks was pushing it for traction in shinny trucks onlt simexs and lockers only or comp trucks, was a real fun day for all
Re: 4/5 july
Posted: Sun Jul 05, 2009 8:41 pm
by gimmemud
Dropped the new body on the surf today and looks mean. Pulled engine apart and had a nice 10mm layer of metal filings. thats 2x blown engines in 6 months, oh man!
On the lookout for a 3.8 v6 vp motor if anyone out there has one.
Re: 4/5 july
Posted: Sun Jul 05, 2009 8:44 pm
by J_Dub
gimmemud wrote:Dropped the new body on the surf today and looks mean. Pulled engine apart and had a nice 10mm layer of metal filings. thats 2x blown engines in 6 months, oh man!
nice 1.. when do ya rekon you will be running again? wheres the pics man?
Re: 4/5 july
Posted: Sun Jul 05, 2009 8:49 pm
by gimmemud
J_Dub wrote:gimmemud wrote:Dropped the new body on the surf today and looks mean. Pulled engine apart and had a nice 10mm layer of metal filings. thats 2x blown engines in 6 months, oh man!
Hopefully back in business next weekend, gonna look for a new motor this week. gonna be fun trying to get the clutch all sorted in the auto body. Didn't really think of it when i bought it
And i managed to forget my camera both days.
Re: 4/5 july
Posted: Sun Jul 05, 2009 9:43 pm
by QUADRACER
also at same day out, broke rear diff, who would have thought , a suzuki would do that
minor compaired to Kaney
Re: 4/5 july
Posted: Mon Jul 06, 2009 1:38 pm
by badnuz
Re: 4/5 july
Posted: Mon Jul 06, 2009 3:55 pm
by swampa
got 3 pigs, saw a few more, saw 2 stags, watched them for a while then left them,saw a few hines, left them too, only after pigs over the weekend
Re: 4/5 july
Posted: Mon Jul 06, 2009 7:00 pm
by sig
water blasted the 40 after rallywoods the previous weekends fun ( that was 4 hours used ) .then started to track down why i had no brake peddle after 20 mtrs of driving and discovered rear drivers side wheel bearing had seen better days (10mm of sideways movement ). just debating whether i fix it or start putting my 60 rear housing in thats in the garage on the floor .
Re: 4/5 july
Posted: Mon Jul 06, 2009 7:52 pm
by safaripete
Re: 4/5 july
Posted: Tue Jul 07, 2009 8:03 am
by badnuz
safaripete wrote:cheers for the invite
is your 40 going?????
bring on costa!!
Re: 4/5 july
Posted: Tue Jul 07, 2009 8:36 am
by curly12
SmurfN wrote: managed to drive home from mates workshop with 1 u bolt in each side and the shocks on each side supporting diff. dodgy i know
That sort of shit kills people
Re: 4/5 july
Posted: Tue Jul 07, 2009 1:01 pm
by Moriarty
curly12 wrote:SmurfN wrote: managed to drive home from mates workshop with 1 u bolt in each side and the shocks on each side supporting diff. dodgy i know
We've ALL done stupid things, Curly, but to boast about it on a public forum is the winner!!!!
B
Re: 4/5 july
Posted: Tue Jul 07, 2009 1:23 pm
by suzolla
Changed out the complete front axle assembly of the 80 series so I can overhaul it. Going to do wheel bearings, CV's, CV support bushes, knuckle seals and should probably do the drive plates as well.
Also thinking about zinc plating so the balls dont corrode.
Tim
Re: 4/5 july
Posted: Tue Jul 07, 2009 8:46 pm
by safaripete
badnuz wrote:safaripete wrote:cheers for the invite
bring on costa!!
haha was jus pullin ya leg mate
