locating a lift kit supplier 185 surf
Posted: Sat Jul 11, 2009 12:58 am
by LOWDWN
am having trouble finding anything to lift my surf with, the efs gear on 4x4bits is only 40mm, anyone know of somwere that does a pre organised lift kit for rzn185?
otherwise ill go to autolighn and slowly peice it together
sam
Re: locating a lift kit supplier 185 surf
Posted: Sat Jul 11, 2009 9:03 am
by coxsy
Posted: Sat Jul 11, 2009 9:36 am
by rokhound
Any more than 50mm on a 185 starts to cause cv angle issues. Why do you need to lift it? IE, what size tyres are you trying to get on?
You can add a 1" diff spacer, that helps with drive line angles, and do a small body lift to help clear chosen tyres.
I have 100mm lift in a 90 series Prado (exactly the same platform as a 185 surf), and did it with 50mm suspension and 50mm body lift. Mine runs 285/75/16 MT's (33" height), and I wouldn't run anything bigger on these trucks as the centre diff on them is an inherrant weak spot.
Posted: Sat Jul 11, 2009 5:16 pm
by LOWDWN
yes i agree with you, also i have been lining up the tradme ones, but i found an old auction of them were the reasr shock is still compressed, think my brandnew old ranchoes did that tho.. still cheap i think
cheers guys
sam
