tia
W
williamhamilton wrote:2nd coat.. looks soooo pretty in silverwon't get a chance for Hippo liner till the end of the week. will post results. that POR stuff is HARD when dry!!
MNC wrote:I see you have removed the seats. Are you going to do the wheel arch's and the floor in the cab too? Since its all ready to go and you're in the mode my vote would be to mask off the edge of the blue paint and do the whole inside of the tub.
That two pot hipo liner will cover this entire area but you better rust treat it first.
MNC wrote:Nice to know there is a good rust killed 40 tub out there - make sure you look after it![]()
williamhamilton wrote:MNC wrote:Nice to know there is a good rust killed 40 tub out there - make sure you look after it![]()
And it can be yours for a lowly price of $10,000(comes with free engine, frame, diffs, axles etc)
williamhamilton wrote:Qustions:
1) how do I check fuel sender in the tank is working?
Its a variable resistor so put an ohm meter on it and ckeck for the change in resistance as you move the arm up and down
2) While the tank is out is it worth cleaning it out? if so,how?read about water and pebbles, alcohol, good strong chemicals or send to radiator place to be done.. any recommendations?
Just flush it with petrol or meths and get all the loose rust scale and crap out and stick it back in, its a 40 year old fuel tank so its going to be on its last legs anyway![]()
coxsy wrote:found a photo of it
williamhamilton wrote:While I am here.. is there a plate missing from here or just how it looks normally?
Sadam_Husain wrote:williamhamilton wrote:While I am here.. is there a plate missing from here or just how it looks normally?
A standard Cruiser rubber boot should fit in there..... helps keep the mud out of your clutch![]()
williamhamilton wrote:...So back to my noob questions again.. refer attached pic. Worth trying to repair this or kill the rust and may it pretty once back on?
