Wanted Urgently: Samurai Diff head or crownwheel/pinion set
Posted: Mon Jul 13, 2009 11:05 am
by HedgeBoar
As the title says, looking for a 3.7:1 samurai rear diff - whole head preferably, but a crown wheel and pinion set will also do the trick.... Would want a crown wheel/pinion set to be in good nick, but I'd be interested in a whole head in any vaguely drivable condition... only needs to be a-framed and driven off road at this stage!
Re: Wanted Urgently: Samurai Diff head or crownwheel/pinion set
Posted: Mon Jul 13, 2009 11:42 am
by icekayak
Are you sure their 3.1's? just seems quite high for a samurai...
Posted: Mon Jul 13, 2009 11:43 am
by HedgeBoar
Sorry, typo, should be 3.7:1. Thanks for pointing that out!
Posted: Mon Jul 13, 2009 11:55 am
by UBZ
I have a 3.7 Rear Samurai Diff head in Pieces. Not pulled apart by me.
Crown and pinion look sweet, is missing the spider gears and i think the bearings need replacing.
U interested?
Chris
Posted: Mon Jul 13, 2009 12:08 pm
by HedgeBoar
Yep interested - is the input shaft still in place? If so, is there any play in it? Just that from my experience, once they've been driven with play in the input bearing the crownwheel/pinion can be stuffed even if they look fine...
How much would you be after for it?
Posted: Mon Jul 13, 2009 12:13 pm
by UBZ
Yeah Input shaft is still in place,Will check it out tonight for ya.
Its of no use to me as I'm running 3.9's.
Make me an offer
Posted: Tue Jul 14, 2009 2:05 pm
by HedgeBoar
Did you get a chance to check the input bearing?
Not really sure what it's worth - how does $100 sound - if the input bearing feels ok?
Posted: Wed Jul 15, 2009 11:46 am
by UBZ
Checked the input bearing.
Has no slop or play that i can feel.
Crown wheel looks to be in good shape with no visible wear or rounding of the teeth.
Diff was pulled apart by a dick and they did not mark bearing cap sides and crown wheel location. They also lost the spider gears.
did you want the whole housing and the bits i have or just the Ring and pinion?
C.
Posted: Thu Jul 16, 2009 10:29 am
by HedgeBoar
Hi, the whole lot would be good if you don't want any of it - Thinking I might be able to just put some new side bearings in it and see how it goes. Spider gears are no prob, I have a few centers floating around.
BTW, I have a good 3.9:1 ring&pinion set and a whole lot of assorted diff & tcase bits lying around if you need anything.
Posted: Fri Jul 17, 2009 9:57 am
by UBZ
had a real close look at the pinion teeth last night and there is a bit on wear and pitting on them. :( Can send you some pics if you want.
As Im know not sure weather the diff will be usable you can have it for the cost for postage.
Will take it in tomorrow morning and get a price for you on postage to Ch Ch.
Don't suppose you have a WT rear diff housing lying around. the one i have is bent :evil:
Posted: Fri Jul 17, 2009 1:12 pm
by HedgeBoar
OK sounds good, I think they come in just under the 25kg limit on standard post so postage is pretty reasonable.
Don't have any sj/sammy housings, but I have some vitara ones.... good excuse to go coils!
Posted: Fri Jul 17, 2009 2:10 pm
by UBZ
:lol: :lol: :lol:
Dreaming of Coils
Have two many mods planed as it is. have to get it on the road first. might just have to stick with NT for the moment. :(
Posted: Thu Jul 30, 2009 3:19 pm
by HedgeBoar
Have you inquired about shipping yet?
Posted: Thu Jul 30, 2009 4:43 pm
by UBZ
Hey mate. Sorry taken me a while to get it sorted.
Normal courier wont take it as to heavy, but can put it in with our freight company and send it with the next load of project gear to Ch Ch. Should be under $50.
We normally get our stuff sent to a depo in Hornby, Is their any particular depo you would want it sent to? pretty sure they can send to any.
C.
