Isuzu Mu after market parts
Posted: Tue Feb 07, 2006 5:28 pm
by tigerman
Does anyone know where i can source parts for setting up a 1994 Mu with a alloy bullbar with winch fitting and suspension lift kit???
Posted: Tue Feb 07, 2006 8:12 pm
by SupraLux
The alloy bars can be sourced from most 4WD shops... but be warned... they are not cheap. I haven't seen any second hand but try asking on
http://www.clubisuzu.com - forum section.
I can supply a suspension lift for them, the 4 long travel gas charged shocks, and 50mm lifted rear springs are $800 for the kit. You can tweak the torsion bars in the front to suit the height you want (within reason).
I have winches as well... check the dealer ads in the front page.
If you can't find a winch bumper to suit, maybe look at other vehicle models and see if they might be able to be modified to suit the MU... you'd need someone who could TIG weld ali, but most engineering shops should be able to do that for you
Hope that helps
Steve
Bars
Posted: Tue Feb 07, 2006 9:32 pm
by 4274sh26
Try Dragon 4x4 Spares, in Te Puke. They had an alloy bar.
Good luck, Paul.
