as per title.
straight bolt in- all bolts etc included.
Lever is modified so that it does not smack the back of the trans tunnel hole when going into 4wdL
can post pics if wanted.
$100 or swap for cool GQ parts.
-Nathan
$100- GQ lift blocks, bolts and modified shift lever.
- flyingbrick
Re: FS. 35mm GQ lift blocks + cut/welded/bent 4x4 lever
changed your mind, huh on body lift.
- flyingbrick
I've got 4" of spring lift which is plenty
forgot to add.
Blocks are Ø70mm uhmwpe with grade 8.8 M12 bolts with new nyloc nuts and washers.
-Nathan
forgot to add.
-Nathan
- flyingbrick
$150.
I think thats a good deal.
- flyingbrick
Re: $100- GQ lift blocks, bolts and modified shift lever.
$100
Need these gone- making a mess of my garage.
- flyingbrick
come on
.. some guy on tm wants $50 just for some "body lift BOLTS"
this has bolts AND lever AND blocks.
