Big list here... I can do deals on more than one item, all prices are open to some negotation, but please no mega low ballas!!!! trying to pay for all my outdoor equiment
I have pics for most, but will make this thread HUGE, so if your interested ask for pics please
PAINTING TOOLS:
Devilbiss Digital air gauge (DGi) with a swivel high flow air fitting, never dropped, has some overspray but still mint working condition, used for around 12months, have good reviews!!!
$120
Devilbiss GTi 'V8' spray gun, has been used professionally for around 12months, has been kept spotless inside, but outside gets overspray etc. as to be expected! comes with 1.4mm and 1.6mm needle/tip setups so mint for priming aswell!!! no issues at all with this
$300
Devilbiss SRi, mini/touch up spray gun, wicked little tool for quick repairs without overspray bloody nice and great devilbiss quality! comes with a 0.8mm needle setup *Barely used*
$200
SANDING TOOLS:
RUPES electric long board sander *SL42AE*, 400x70mm velcro backing for sand paper(3M make suited sheets) with vaccum connection, mint condition, used for approx 12months
$300
Vaccum hand long board 400x70mm, takes same velcro sheets as RUPES longboard, great for blocking with no dust!!
$50
Vaccum Block, half A4 size, takes velcro sheets, great for blocking back primer!
$50
Hand long board, 400x70mm with good clips, just takes uses the sand paper rolls, mint condition
$25
Rubber/wet sand block, as it sounds, handy little block for final sanding/spot putty
$10
OTHERS:
Body/Panel file and handle, steel handle/body has screw for adjusting curve of blade, comes with 2 blades, both mint condition
$60
Basic air tool kit, has suction feed spray gun, degresser pot/gun and air blower, comes with short coil air line aswell
$25
Assortment of sandpaper, rough list as follows:
-1x sleeve P400 A4 sheets
-A4 sheets, random selection ranging from P80-P1200 (approx. 30sheets)
-150mm orbital velcro sanding discs(with vac holes) ranging from P80-P400 (approx. 100discs)
-400x70mm velcro sheets(to suit Rupes electric long board etc.) ranging from P40-P240 (approx. 50sheets)
-3M sctoch-brite, Red and Grey (approx. 20pieces)
-3M Sanding sponge, Fine and Superfine (approx. 10 pieces)
This would be close to $100 worth of sand paper, all 3M brand so good quality!
$40
3M plastic masking as follows:
-2.5 Rolls MF72" (opens out to 72" wide, 1 roll is approx. 50meters from memory)
-0.75 Roll MF99" (opens to 99" wide)
good plastic, is great for cars or masking houses for painting!
$15
3M masking tape as follows:
-1x 2" ordinary masking tape
-2.5x 18mm GREEN masking tape(green has better stick, gives good paint edges)
-1x 18mm ordinary masking tape
$15
2x 3M respirators with used filters, great for people doing a home job of painting, give it a good clean(recomended for hygiene) and some new filters and it will be as good as new!!!
$30each
ANY NEGOTIATIONS STRAIGHT TO PM PLEASE
FS, not car parts, but painting tools....
http://www.kiwiracer.com/bb/
