Bumper fab
I wanted to build new front and rear bumpers for a couple of reasons.
Firstly, both the front and rear bumpers on a factory 60 series cruiser limit approach and departure angles quite drastically. It is especially bad in the rear of these wagons because they have a big fat ass that tends to drag on things, the low slung factory rear bumper and tow bar makes it even worse. I had a factory PTO winch bumper on the front and decided to take it off. The number of places that the 400+mm platform bumper had limited me from going was greater than the number of places that the winch had saved me from, so it was gone. It also created another $500 to my budget after selling it on trademe.
Secondly, the 50mm gap left by the bodylift needed to be filled and looked stupid IMHO.
The first pic shows the panels put back on after paint and the middle section of the front bumper fitted up for test.
First step to designing the bumpers was surfing the likes of IH8MUD forums for stuff other people had done, and trying to find somoething I liked. After compiling a folder full of bumpers I had a general idea what I was after, so I stole a bunch of cardboard from work and got me old tape measure out.
Having gotten in touch with my artistic self and made a cardboard template, I had a piece of 3mm steel plate folded up to my specs, and ripped into it with the grinder.
The folded inserts that sit inside and bolt to the chassis rails are also 3mm plate, however the strength of the bumper mounts come from the 10mm flat bar which also extends through the front of the bumper and can be used as tow points.
The strength of the bumper comes from 100mmx50mm steel box section that sits snugly ontop of the chassis rail mounts and runs the full length and contour of the bumper, including the side 'wings'. You can also see from the above pic that I have made the bottom of the bumper start at the chassis rail, so the lowest point of the front of the truck is now the chassis, this is a VAST improvement over the factory setup, and hides the body lift nicely.
