FUCHS oil...
muddyplumber
- Spring Free
FUCHS oil...
have a cruiser with 13bt in it, brought FUCHS gbox,transfer an engine oil from BNT. now im in two minds is this oil ok to use, never really heard much about it.do i use it now iv got it or take it back n use something else
Rich
Re: FUCHS oil...
have used in both my current and previous LJ71's diffs and motor...have been advised to use Penzoil in the gearbox and transfer case for cruisers as its slightly thicker and keeps it a bit quieter....gearbox is a bit ratty when cold but when warm its nice and smooth....had no issues with the fuchs oil. I usually do my engine oil every 2500k on the pos anyway given its used mostly offroad....and i do the diffs etc every 5000k as you normally get a bit of water in even with breathers....
http://www.fuchs.com.au/home.asp
muddyplumber
- Spring Free
Re: FUCHS oil...
thats good to no someone else has used it
have already put it in the diffs but was just stalling on doin the motor till i had heard what people thought of it.
Re: FUCHS oil...
I used to work at Hertz, and they put it in the rental cars that they serviced themselves, (Falcons, Territories and Explorers) the Toyotas were all sent offsite.
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
- skid
- Tyre Man
Re: FUCHS oil...
its fine, unless you've won lotto
then you go buy redline oil
Re: FUCHS oil...
nothing wrong with Fuchs oils. We use it at work for everything generators and trucks.
I use it myself never had any trouble with it. even use it in my qaud and plan on use it in my racecar.
I know some large earth moving and minning virms that only use Fuchs.
so go hard with it, good oils.
Re: FUCHS oil...
i used fuchs oils in my diffs no problems at all but now i do run redline in my diffs now
vince
vince
