Does any know what the engine oil pressure should b on a 3L
Ive gt 23psi at idle 600rpm
and 66psi at 2000rpm
3L (2.8) engine oil pressure
- Bulletproof
Re: 3L (2.8) engine oil pressure
Xr246 wrote:Does any know what the engine oil pressure should b on a 3L
Those figures are high if the engine is properly hot
It takes a least 10K to bring oil tmperature up to normal running temperature
Cheers Richard
Never say die, up man and try
I took it for a good 5 to 10 min drive before putting the gauge on
I got told to check my oil pressure before i turbo it
