avm manual locking hubs noise
sambo
Post by sambo »
hi i just bought some avm maual locking hubs for a ln130 surf and they are making a rubbing noise when i drive on them, it happens in 4 and 2 wheel drive, any help would be appreciated
cheers sam
pos nissan patrol
Ln106 single cab
mudlva
Re: avm manual locking hubs noise
Post by mudlva »
youve put them on wrong and its fowling the stud axle. pull them off and make sure that the hub is in the free position as well as the gear inside is pulled back to into the hub. big problem people have is when installing the hub they invertantly turn the inside gear and then when its bolted up it wont engage the shaft as it should
hope that helps
Return to “Tool Shed”
