fj 40 diff rear issues
Posted: Wed Sep 09, 2009 7:23 pm
by kruza wazza
semi to full floating mod' on rear. will i have to change diff housing to do this mod or not, will it just bolt up and be a dream , ? cheers wazza
Re: fj 40 diff rear issues
Posted: Wed Sep 09, 2009 10:16 pm
by Sadam_Husain
yep you'll have to change the housing, hubs and axles :mrgreen:
Posted: Wed Sep 09, 2009 10:17 pm
by MNC
kruza wazza wrote:semi to full floating mod' on rear. will i have to change diff housing to do this mod or not, will it just bolt up and be a dream , ? cheers wazza
I'm not sure but if I was going to do it i'd go for the full housing swap out. Would be easy to do - jack up, remove drive shaft, remove brake line & shocks, undo u-bolts - swap diffs and reverse...
