MILE MARKER WINCH INSTALLATION - NISSAN GQ SWB
For all Nissan related topics
mex
Newbie
Newbie
Post by mex »
Hello all from Oz,
I am interested in installing a Mile marker hydraulic winch on my Nissan SWB GQ. I have a petrol/gas engine with a standard 5-speed transmission behind it. The transmission has the blanking plate on the side where the PTO option goes. What I would like to do is run a hydraulic pump off the PTO to drive the winch. Ideally I don't want to use the powersteering pump due to speed issues.
First question: Can anyone here recommend a 4WD wrecker that I could contact to purchase the PTO & get it sent to QLD Australia. They are rarer than rocking horse shit over here.
Second question: Has anyone here got a hydraulic winch running off a pto pump. From watching the NewZealand comps on "4wd tv" you seem to be experts on getting good line speed from hydraulic winch setups. I would appreciate any advice based on your experience to help select a pump with the appropriate flow rate & pressure rating.
Hopefully I can spend my money right the first time.
Cheers Ian :D
Re: MILE MARKER WINCH INSTALLATION - NISSAN GQ SWB
Hi there cobber
theres usually a pretty regular supply of nissan pto's (complete pto winches) floating around on www.trademe.co.nz but it might be a bit hard to get someone to send one over to Oz for you :oops: :mrgreen:
albundy
Rolly Polly
Post by albundy »
Jamie at Automotive Parts, 32 Edward st Rangiora, just out of Christchurch. 03 3137216. He only deals in Nissan 4wd parts and supplies alot of sth island panel beaters with parts as well as 4wd shops and safari/patrol owners. Tell him Albundy put you on to him.
Al
vvega
Post by vvega »
specs on motor and max preasure on pump ?
flow requirements etc
are you happy with in cab hydraulic controls ?
Kiwi4x4
MaccaOz
Post by MaccaOz »
Mex, give PowAuto a call:
QLD, Coopers Plains
Tel: (07) 3277 6888
QLD, Rocklea
Tel: (07) 3875 1100
QLD, Toowoomba
Tel: (07) 4634 5777
My PTO is a PowAuto one (driving a Thomas winch, which Powauto also deal in).
Another option - PM HeliSat on patrol4x4.com - I know he's very recently bought a PTO winch & all the gear to put onto his GQ. He might be able to give you some indication of where else to look.
Macca
1990 Nissan GQ Patrol - 4" and a bit lift, Drop Boxes, 33" Maxxis MT's, 4 x HID Cibie's, PTO winch
GQTROL
Post by GQTROL »
Talk to Sandy Bowman at AUS4WD in Bayswater, he's just started up his shop again.
I've sent 3 or 4 complete units to AU over the last few years, but he seems to have a local source for them now.
flyingbrick
Post by flyingbrick »
sorry about the bump but...
the thread starter seems to think that the factory pto winches are hydraulic... they arent :?: unless im missing something crucial.
gimmemud
Post by gimmemud »
using pto to drive hydraulic pump i think is what he's saying
DaveM
Post by DaveM »
mex wrote:What I would like to do is run a hydraulic pump off the PTO to drive the winch. Ideally I don't want to use the powersteering pump due to speed issues.
Cheers Ian :D
flyingbrick
:lol: im a fool.
Just kept reading PTO pump.
I have the same questions ATM you see. :mrgreen:
