MILE MARKER WINCH INSTALLATION - NISSAN GQ SWB
Posted: Thu Sep 10, 2009 7:16 pm
Hello all from Oz,
I am interested in installing a Mile marker hydraulic winch on my Nissan SWB GQ. I have a petrol/gas engine with a standard 5-speed transmission behind it. The transmission has the blanking plate on the side where the PTO option goes. What I would like to do is run a hydraulic pump off the PTO to drive the winch. Ideally I don't want to use the powersteering pump due to speed issues.
First question: Can anyone here recommend a 4WD wrecker that I could contact to purchase the PTO & get it sent to QLD Australia. They are rarer than rocking horse shit over here.
Second question: Has anyone here got a hydraulic winch running off a pto pump. From watching the NewZealand comps on "4wd tv" you seem to be experts on getting good line speed from hydraulic winch setups. I would appreciate any advice based on your experience to help select a pump with the appropriate flow rate & pressure rating.
Hopefully I can spend my money right the first time.
Cheers Ian
Cheers Ian
