Pajero Stuff Help !!
- Driver/Navigator
I m after alloys to go on a soft top pajero ... winch & free wheeling hubs. Any for sale ? any bargain places ... please help !
- northland_pajero
Re: Pajero Stuff Help !!
I have a set (5) 15x7 factory pajero alloys if your interested
They wont fit the front without spacers, they don't clear the brakes. You need at least a -30 offset in a 15" alloy rim to clear the brakes.
- Driver/Navigator
Thanks for the info ... Cheers!
- Driver/Navigator
Hi ! Thanks for the info. Ur truck looks awesome. Please, What mods did u have to do to get 35s in . cheers !
Patrol springs in the rear, 4 1/2" lift. Replace shocks with Hilux ones.
Crank the torsions as much as you can, removing the droop stops and replacing with strips of rubber.
Either trim the front bumper alot or remove altogether.
Balljoint flip with a spacer and bigger bolts.
35's fit with these mods but you get a small amount of rub at certain steering angles so a 2" bodylift will sort this out, I went 60mm. Oh and you'll also need a decent amount of offset on your wheels to stop fouling on the insides of the guards, mine are -32.
- Driver/Navigator
Wicked !! Cheers !
