It's happened a few times for me. But i don't get on here as much these days.
Does anyone else try and jump on here and it doesn't load?
But to the moderators here thanks. You people do well.
ORE OFFLINE
Re: ORE OFFLINE
yes about 6 time from loose memory, but i do have patrol forum to look at too
- muddyhilux
Re: ORE OFFLINE
yeh ive had this recently,at work and at home,wont say its offline,just simply wont load
Re: ORE OFFLINE
Not that it matters much.
How come we get two different style emails doing the same thing?
One coming from:
"www-data@offroadexpress.co.nz"
With this style format:
"=?UTF-8?B?aWtlIg==?=
Reply-To: <mike@ore.co.nz>
Sender: <mike@ore.co.nz>
MIME-Version: 1.0
Message-ID: <ddb5c7a7b90257255136f29d570938ad@www.offroadexpress.co.nz>
Date: Wed, 16 Sep 2009 21:40:32 +1200
Content-Type: text/plain; charset=UTF-8
Content-Transfer-Encoding: 8bit
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: PhpBB3
X-MimeOLE: phpBB3
X-phpBB-Origin: phpbb://www.offroadexpress.co.nz/oreforums
Hello petefj40,
You are receiving this notification because you are watching the topic, "Me
siss new V8 Trike" at "Offroad-Express". This topic has received a reply
since your last visit. You can use the following link to view the replies
made, no more notifications will be sent until you visit the topic.
If you want to view the newest post made since your last visit, click the
following link:
http://www.offroadexpress.co.nz/Forums/ ... 2&e=205732
If you want to view the topic, click the following link:
http://www.offroadexpress.co.nz/Forums/ ... 69&t=18011
If you want to view the forum, click the following link:
http://www.offroadexpress.co.nz/Forums/ ... m.php?f=69
If you no longer wish to watch this topic you can either click the
"Unsubscribe topic" link found at the bottom of the topic above, or by
clicking the following link:
http://www.offroadexpress.co.nz/Forums/ ... atch=topic
Thanks, The Management"
Or just the normal:
"mike@ore.co.nz"
With the usual looking format.
"Hello petefj40,
"ORE OFFLINE" at "Offroad-Express". This topic has received a reply since
your last visit. You can use the following link to view the replies made,
following link:
http://www.offroadexpress.co.nz/Forums/ ... 4&e=205734
http://www.offroadexpress.co.nz/Forums/ ... =6&t=18010
http://www.offroadexpress.co.nz/Forums/ ... um.php?f=6
One coming from:
MIME-Version: 1.0
X-Priority: 3
X-Mailer: PhpBB3
X-MimeOLE: phpBB3
Hello petefj40,
following link:
Or just the normal:
"mike@ore.co.nz"
"Hello petefj40,
following link:
- mike
- Last minute Mike
Re: ORE OFFLINE
there is at the moment an unusal bug in the site which is causing the server to pretty much go into an infinite loop. I've got something that fixes it within a couple of minutes of it happening. the cause is unknown to me but hopefully the pattern of when it happens presents itself as I'm trying to record details of what is happening when it happens (random times and random actions on the site grrr)
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
Re: ORE OFFLINE
I knew you'd be onto it Mike.
You're the man!
You're the man!
