Monster 150 Air Compressor - Traxion
Posted: Thu Sep 17, 2009 7:20 am
by SirGerald
Hi all
Looking at mounting my old bushranger air compressor into my truck as I have built the roll cage to be my air tank (had originally planned to use engine mounted air comp but no room)
As it is a trials truck not looking to pump all 4 up from 3psi but will need to pump up and down during the day as well as use to pump up after replacing tubes etc.
My old Bush Ranger pumps out at about 35litres per min I think but have come across this one that does 150 litres per min and costs around the $250 mark.
http://www.traxion.co.nz/product/spec/specForce.pdf
Has anyone used one before??
Anyone got any advise if they are any good or not as appear to be a heap higher flow rate compared to others.
Re: Monster 150 Air Compressor - Traxion
Posted: Thu Sep 17, 2009 7:52 am
by haynzy
I have the arb high output comp and it blows about 72lpm, best thing is it comes with all the required loom and pressure switches all set up and if it dies arb have most stuff in stock to fix it. Only neg is they are about $400 notes :( but hey luckily for me the dumb asses who stripped my truck didnt know what it was and left it there :lol:
Posted: Thu Sep 17, 2009 9:09 am
by DieselBoy
With out seeing the Traxion one in the flesh, it looks nearly identical to one's in Supercheap :D :D
Posted: Thu Sep 17, 2009 5:58 pm
by tweake
Posted: Thu Oct 15, 2009 7:35 pm
by flyingbrick
If its the same as the projecta typhoon (assuming since the link above goes to info on that pump.. i cant view the pdf) then its a very good pump. Australian 4wd action magazine No131 tested a whole bunch and this pump was recommended and they said its speed and consistency were noticeable standouts.
Hope this helps.
Posted: Thu Oct 15, 2009 7:57 pm
by coxsy
I got a typhoon pump does the job, fast recomend them and will buy another if and when it dies
Posted: Fri Oct 16, 2009 10:43 am
by Mud Hog
Yeah I am waiting for one of these, and one of the nissan factory style manuel locking hubs they look much stronger than the superwinch and AVM ones, Force make them, Has any one heard any feed back on these?
