new rim size for 1995 surf
snork
Post by snork »
What wheel rim size do i need to get to suit 32x11.5x15 tyres?
i know its 15" in diameter but not too sure on which width to use
im after those white steel rims
cheers,
Martyn
Landscaper
Re: new rim size for 1995 surf
Post by Landscaper »
Depends on what tyres probably 7 or 8'' go to 4wd bits and look at their tyres as they state manufactures recomended rim sizes. BUT what offset ?
haydgq
Post by haydgq »
Yea either 7 or 8 Inch wide will fit no worrys, You can also use the widest offset 15X8's that are usually for landcruisers/Patrols etc and they will give you a bit more width if you want it but they might also rub a little more.
snork
Post by snork »
its been lifted so i its shouldnt rub with a low off-set
i will go looking for sum of those then...thanks
UBZ
Post by UBZ »
Im running 15x8 -19 offset. with 33x12.5 BFGs. My tyres sit just inside the factory wide body flares.
You can use -24 offset as well.
T-Boon
Post by T-Boon »
hey man, i can get you some like mine if you want? 15x8 -19 would be about flush with your flares, ROH so they balance good, bout $100 a rim i think? white or black ?
To Boon or not to Boon.
