What other degreaser do you guys use....
CRC Aeroclean Degreaser
This works amazingly well, just dont go to repco to get it as I found put today! They stock it but charge $17 per can! If you go to Bunnings they have the same thing (same size can aswell) for $9.16
for a 500ml can....
toymota thats stock standard.
Re: CRC Aeroclean Degreaser
If you tell RIPCO that you can get it cheaper elsewhere they will match the price.
Never tried the CRC stuff, I've only ever used the Supercrap stuff, works well for the price.
CRC brakeclean for normal duty
CRC XD4 for the more serious stuff...like dont leave it on plastic too long
That crc brakeclean stuff is Awesome! When i was watching my diff get setup the guy was using heaps of it, cleaned all the oil and crap off the outside as well very easily, will be getting me some when i clean my engine up.
I avoid using Aerosol Dereaser's
Brake Parts Cleaner does seem to work very well.
In the long run it works out better to get 20L of Tergo Industries Enviro De greaser.
With the added bonus that it can be filtered and reused.
non toxic blah blah, it also works better.
used the crc brakeclean and degreaser on site at anz to help with the 25 years of crud on the top wheels help lock the bearings in
Wurth Brake cleaner works better than the CRC stuff imo and isnt hard on plastic.. work buys it buy the box so its cheap too
LPS HDX...otherwise Wynns Brake and part cleaner (I think that's what it's called). IMO better than Brakleen
