ln106 with kzn130 surf project
uwish
Post by uwish »
looking at putting the motor and trans(auto) from a kzn130 into my ln106.also would like to put the interia with power windows ect into it. what i want is info on doin this what you can and cant use any tips or problems?
i was thinking off just putting the whole loom from the 130 in to the d/c and the dash the whole works has this been done? does it work?
any help would be great thanks
lexlux
Re: ln106 with kzn130 surf project
Post by lexlux »
i have a 93 sc flatdeck 1kzte & auto ,4.55 diffs ,it flyes .
its a cheap conversion best to buy a wreck ,getting one with good kms is the trick, every thing fits in ,there the same truck just takes time .
with the auto i had to get the rear driveshaft shortened ,& a 2.5 in exaust thats the only costs involved.
i gave the cab a 25mm body lift to clear the 32 in simexs.
uwish
Post by uwish »
thanks for that so did you use the kzn130 dash and loom? do the front gards and doors bolt on? yeah ive got a wreak lined up with just over 100kms so should be good
lexlux
Post by lexlux »
yes loom,dash,haeters ,the lot ,front guards doors it all fits .
but not the surf lights & grill, you have to un pick the front raditor panel &swap that over if you want the big surf lights .
uwish
Post by uwish »
can i use the front screen out on the kzn130 surf? as its guled in rather than a rubber like the hilux? also am i best to use the front calipers of the surf? are they better than the hilux ones?
lexlux
Post by lexlux »
not sure about the screen i thought they were different ,front calipers are the same its just the surf ones may be in better nick , you can swap over the rear brakes to .
cheers .
uwish
Post by uwish »
i say the surf ones prop are as the surf has done 116xxxkms and the double cab has 386xxxkms
kaney
Post by kaney »
my understanding the calipers are different, have a different offset, the whole ifs caliper isnt in full contact with the solid axle rotor, grind a couple of mm off and shell be right http://www.offroadexpress.co.nz/Forums/ ... =30&t=3543
toymota thats stock standard.
hosehustler
Post by hosehustler »
kaney wrote:my understanding the calipers are different, have a different offset, the whole ifs caliper isnt in full contact with the solid axle rotor, grind a couple of mm off and shell be right http://www.offroadexpress.co.nz/Forums/ ... =30&t=3543
callipers are the same, what Kaney has written only applies when you put IFS hubs on to a solid axle to widen it out wheel track, and when the IFS rotor is used as it's not quite as large in diameter as the hilux rotor.
I hate signatures
U-BOAT
Post by U-BOAT »
May pay to measure the calipers as my KZN130 that i wrecked run 25mm front discs and LN106's run 20mm thick discs. Also even though they bolt on because the caliper is wider you can't bolt your rims on without doing and an IFS hub swap as the rims foul on the caliper. just my 2c
